So I currently have:
Case: Silverstone DS380
CPU: ASRock Intel Core i3-4160 LGA 1150
Mobo: ASRock E3C224D2I Mini ITX Server Motherboard LGA 1150 Intel C224
HDDs: 8x WD Red 4 TB
And I am finally building out a rack and am planning on dropping most of everything into a Super Micro 846 rackmount case with 24 bays (only $130 on Ebay). Since the Mini ITX board only has a single PCI slot, I can't really utilize more than 8 drives with only a single M1015 HBA card in IT mode, which has made me come to the decision that I need a bigger form factor motherboard with more PCI slots for future drive expansion (plus there are not many Mini ITX rackmount cases OOTB).
I was thinking of switching to: ASRock E3C224 ATX Server Motherboard LGA 1150 Intel C224
My question is, should I theoretically be able to just pull my CPU/RAM/HBA/HDDs out of the MiniITX tower and with this new mobo (and rackmount PSU), just drop everything into the SuperMicro 846 case and fire it up and my existing FreeNAS array should theoretically still work? Or will I have to re-create the zpool from scratch or do some kind of re-configuration?
Also does the manner in which the drives are connected to the back plane matter? i.e. top 4 drives in my current tower are connected to HBA0 plug and bottom 4 to HBA1 plug, or does FreeNAS know which drives belong to the array based upon physical drive id/serial#?
