I'm struggling to find a motherboard to use in the file server build I have been planning. Going in, I had the following specs in mind for what I was looking for, and I didn't think they would be too tough to find:
- mini-ITX form factor
- At least 5 SATA ports (3 or 6 Gb/s doesn't matter)
- Intel LAN
After a fair amount of searching, the only boards I could find matching these criteria were:
JetWay JNC9BU-HM67 LGA 1155 Intel HM67 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
JetWay JNF9A-Q67 LGA 1155 Intel Q67 HDMI SATA 6Gb/s Mini ITX Intel Motherboard
These are a bit more expensive than I would have hoped, I haven't heard of Jetway before, and I have no need for dual ethernet. Does anyone have any experience with these boards, and will they even be supported by FreeNAS? And are there any others MBs fitting my criteria that I may have missed?
And if all else fails, should I:
- Drop the requirement for a board to use onboard Intel LAN and buy a LAN card? I feel like I shouldn't have to do this in 2012.
- Drop the requirement on the number of SATA ports and get a PCI SATA card? Probably the best alternative, but I wanted to avoid buying this extra piece of hardware.
- Drop the mini-ITX form factor all together, since it seems like there are just too many compromises you have to make when buying a motherboard?
- Intel LAN
