Peter Jakab
- Jun 18, 2015
Hi All,
I would like direct copy between NAS servers (I already now how to do with SCP command and Rsync).
I would like the third option remote mount Samba share on the other system.
The two server hostname/ip:
demoFNAS/192.168.10.34 (the new test system updated to latest FreeNAS-9.3-STABLE-201506292130)
freenas/192.168.10.8 (the old one FreeNAS-9.2.1.9-RELEASE-x64 (2bbba09)
Sambaclient test show share from demoFNAS on old NAS:
and reverse from old NAS to demoFNAS:
I try to mount from new demoNAS the old NAS:
As you can see the mounted folder emty. Meanwhile the shared folder have hundreds of folders and files.
Mount command confirmed (just last line in mount output):
I try different commands formats:
And also from reverse direction:
But those also not worked for me.
When I first time build up the DemoNAS that is worked from old to new one. But not for reverse direction.
Why this is not works? Could any access right problems behind it?
Bye,
Peter
[root@freenas] /mnt# smbclient -L 192.168.10.34 -U="jpeter"
WARNING: The "acl check permissions" option is deprecated
Enter jpeter's password:
Domain=[TELTEAM] OS=[Unix] Server=[Samba 4.1.18]
Sharename Type Comment
winshared Disk
z2winshare Disk
IPC$ IPC IPC Service (Demo FreeNAS Server)
Server Comment
DEMOFNAS Demo FreeNAS Server
NAS FreeNAS Server
Workgroup Master
TELTEAM NAS
[root@demoFNAS] /mnt/z2test# smbclient -L 192.168.10.8 -U="jpeter"
Domain=[TELTEAM] OS=[Unix] Server=[Samba 4.1.12]
IPC$ IPC IPC Service (FreeNAS Server)
TS-CIFS Disk
Server Comment
NAS FreeNAS Server
PETI-WIN7X64
Workgroup Master
TELTEAM NAS
[root@demoFNAS] /mnt/z2test# mkdir /mnt/tester [root@demoFNAS] /mnt/z2test# mount_smbfs -I 192.168.10.8 //jpeter@NAS/TS-CIFS /mnt/tester Password: [root@demoFNAS] /mnt/z2test# ls -la /mnt/tester total 0 [root@demoFNAS] /mnt/z2test#
//JPETER@NAS/TS-CIFS on /mnt/tester (smbfs)
mount_smbfs -I 192.168.10.8 -W TELTEAM //jpeter@freenas.TELTEAM/TS-CIFS /mnt/tester mount_smbfs -I 192.168.10.8 -W TELTEAM //jpeter@freenas/TS-CIFS /mnt/tester
[root@freenas] /mnt/TriSister# mount_smbfs -I 192.168.10.34 //jpeter@DEMO-NAS/z2winshare /mnt/testcopy Password: [root@freenas] /mnt/TriSister# ls /mnt/testcopy/ [root@freenas] /mnt/TriSister# ls -l /mnt/testcopy/ total 0
Bye,
Peter
