Hi, I'm planing to add another pool and upgrade my motherboard for a new one (m5a78l-m) in order to be able to increase RAM memory because in my current setup it is limited to only 8GB because of the motherboard and according to the TrueNAS dashboard it is permanently maxed out.
But before I do that I'd like to make sure that I correctly understand that I can simply unplug the three 8TB drives of my first pool from the old motherboard and simply plug them into any SATA ports on my new motherboard and after booting up the system the pool should simply show up like nothing happened and I should be able to access all data on the discs.
If that is so I'd also like to ask if I can unplug the three drives from the motherboard (SATA2) and plug them into my 9240-8i (SATA3) instead and still simply boot up the system and the pool and all data in it will still show up like it was before the upgrade.
I'm running TrueNAS-12.0-U5.
CPU: FX-4300
MB: N68C-GS FX
RAM: 8GB DDR3 (max)
HDD 3x8TB
CPU: FX-4300
MB: N68C-GS FX
RAM: 8GB DDR3 (max)
HDD 3x8TB
