I'm considering replacing my motherboard with an identical model board as I have been quite happy with it and it seems to be holding up fine with the latest update to 11.3. I'm wanting to replace because of a recent storm that took out one of the NIC's. I've read in other posts that it's a fairly easy swap, backup the config, swap the board, then boot. It seems the only "hangup" would be my server uses a static IP and the new NIC will have a different MAC than what's in the FreeNAS boot config. Upon reboot this could be fixed through the CLI, but could I avoid this if I set the NIC to DHCP before I swap the motherboard? I think I would get the new IP address from the Console Menu upon reboot and then I would just use it to get to the GUI from there. I'm sure the steps for changing manually in the CLI are probably not that complicated, but I'm just trying to make this as painless as possible. Thanks
