Missing drivers for UPS service
I'm currently setting up my first TrueNAS system (running TrueNAS-SCALE-22.02.4) and am trying to get the UPS configured.
My UPS is a PowerWalker VI 2200 SHL which according to the NUT compatibility list uses usbhid-ups as the driver.
Unfortunately, the UPS service on the NAS only shows me blazer_ser and blazer_usb versions for PowerWalker devices, but machines from other vendors do have a usbhid-ups driver listed.
Can I just select some other device which uses usbhid-ups or will that cause issues?
Thanks in advance.
Redcoat
Welcome to the forums!
That would be my first choice - the NUT situation has always had idiosyncracies...
LarsR
I'm also using a Powerwalker VI 2200 RLE and just chose the usbhid-ups from a different vendor. works nevertheless.
