When I plug in my UPS and check with dmesg it reports as being plugged into ugen1.3. When I set the ups settings to /dev/ugen1.3 I get a disconnected device error (and corresponding e-mail). However, manually typing /dev/ugen0.3 as my port works. (no coms error e-mails, onbatt and on power e-mails as expected after testing). When I run 'ls /dev/ugen*' there is no /dev/ugen0.3. Also in the dmesg log, it says ugen0 is a USB3 port and the UPS is definitely not plugged into a USB3 port.
Should I worry, or is everything good as long as it works?
