Felix_True
- Aug 22, 2021
I'm running TrueNAS Core "TrueNAS-12.0-U5.1", booting from "Samsung FIT Plus 32GB Typ-A 200 MB/s USB 3.1 Flash Drive". I have two of them, running a mirrored boot-pool.
After the reboot initiated by updating to 12.0-U5 the system came up, telling me that the boot pool is degraded. Looking closer shows:
I'm not surprised that mirroring da0p2 to da0p1 doesn't work. /dev/da1 is not present any more. So I removed the Flash Drive that represents /dev/da1 und plugged it in again. Without any futher interaction, the system recognized /dev/da1 and started doing the right thing:
dmesg shows that da0 was identified at boot time, da1 was not:
When replugging the Flash Drive it was immediately identified:
Any hints what I can do to make both Flsh Drives be identified at boot time?
Why does TrueNAS "replace" the mirror to da0p2 with da0p2 if da1p2 is missing? Is this intended behaviour? Why not something like "disk missing"?
root@vault[~]# zpool status boot-pool
pool: boot-pool
state: DEGRADED
status: One or more devices could not be used because the label is missing or
invalid. Sufficient replicas exist for the pool to continue
functioning in a degraded state.
action: Replace the device using 'zpool replace'.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-4J
scan: scrub repaired 40.5K in 00:02:22 with 0 errors on Wed Aug 18 03:47:22 2021
NAME STATE READ WRITE CKSUM
boot-pool DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
da0p2 ONLINE 0 0 0
da0p2 FAULTED 0 0 0 corrupted data
errors: No known data errorsI'm not surprised that mirroring da0p2 to da0p1 doesn't work. /dev/da1 is not present any more. So I removed the Flash Drive that represents /dev/da1 und plugged it in again. Without any futher interaction, the system recognized /dev/da1 and started doing the right thing:
pool: boot-pool
state: ONLINE
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Sun Aug 22 13:14:25 2021
7.05G scanned at 185M/s, 447M issued at 11.5M/s, 7.05G total
443M resilvered, 6.19% done, 00:09:50 to go
boot-pool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
da0p2 ONLINE 0 0 0
da1p2 ONLINE 0 0 0 (resilvering)
errors: No known data errorsdmesg shows that da0 was identified at boot time, da1 was not:
Root mount waiting for: usbus0 ugen0.2: <Samsung Flash Drive FIT> at usbus0 umass0 on uhub0 umass0: <Samsung Flash Drive FIT, class 0/0, rev 3.10/11.00, addr 2> on usbus0 umass0: SCSI over Bulk-Only; quirks = 0x4000 umass0:8:0: Attached to scbus8 da0 at umass-sim0 bus 0 scbus8 target 0 lun 0 da0: <Samsung Flash Drive FIT 1100> Removable Direct Access SPC-4 SCSI device da0: Serial Number 0319521010021458 da0: 400.000MB/s transfers da0: 30594MB (62656641 512 byte sectors) da0: quirks=0x2<NO_6_BYTE> usb_alloc_device: set address 3 failed (USB_ERR_IOERROR, ignored) ... usbd_setup_device_desc: getting device descriptor at addr 3 failed, USB_ERR_IOERROR usbd_req_re_enumerate: addr=3, set address failed! (USB_ERR_IOERROR, ignored) usbd_setup_device_desc: getting device descriptor at addr 3 failed, USB_ERR_IOERROR usbd_req_re_enumerate: addr=3, set address failed! (USB_ERR_IOERROR, ignored) usbd_setup_device_desc: getting device descriptor at addr 3 failed, USB_ERR_IOERROR usbd_req_re_enumerate: addr=3, set address failed! (USB_ERR_IOERROR, ignored) ... usbd_setup_device_desc: getting device descriptor at addr 3 failed, USB_ERR_IOERROR usbd_req_re_enumerate: addr=3, set address failed! (USB_ERR_IOERROR, ignored) usbd_setup_device_desc: getting device descriptor at addr 3 failed, USB_ERR_IOERROR
ugen0.3: <Samsung Flash Drive FIT> at usbus0 umass1 on uhub0 umass1: <Samsung Flash Drive FIT, class 0/0, rev 2.10/11.00, addr 4> on usbus0 umass1: SCSI over Bulk-Only; quirks = 0x4000 umass1:9:1: Attached to scbus9 da1 at umass-sim1 bus 1 scbus9 target 0 lun 0 da1: <Samsung Flash Drive FIT 1100> Removable Direct Access SPC-4 SCSI device da1: Serial Number 0374121030003565 da1: 40.000MB/s transfers da1: 30594MB (62656641 512 byte sectors) da1: quirks=0x2<NO_6_BYTE>
