Hi all,
Been trying to install 9.3 on a brand new Sandisk Ultra Fit USB drive. The installation process works fine, but following a reboot, the drive seems to be disconnected due to I/O Error and subsequently couldn't finish mounting ROOT.
The error seems specific with this Sandisk drive as I've installed 9.3 successfully on the same machine with other non Sandisk USB drives. Really hoping to be able to use this drive since it's low-profile and doesn't stick out of our server racks.
FreeNAS image: FreeNAS-9.3-STABLE-201412312006.iso
Hardware: Dell PowerEdge R515 with Perc H200 card
Any ideas???
Thanks
uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
uhub0: 3 ports with 3 removable, self powered
uhub1: 3 ports with 3 removable, self powered
uhub2: 3 ports with 3 removable, self powered
uhub3: 3 ports with 3 removable, self powered
uhub4: 3 ports with 3 removable, self powered
failure at /fusion/jkh/93/FN/FreeBSD/src/sys/dev/mps/mps_sas_lsi.c:667/mpssas_add_device()! Could not get ID for device with handle 0x0009
mpssas_fw_work: failed to add device with handle 0x9
usb_alloc_device: set address 3 failed (USB_ERR_TIMEOUT, ignored)
usbd_setup_device_desc: getting device descriptor at addr 3 failed, USB_ERR_IOERROR
usbd_req_re_enumerate: addr=3, set address failed! (USB_ERR_TIMEOUT, ignored)
usbd_setup_device_descr: getting device descriptor at addr 3 failed, USB_ERR_IOERROR
ugen2.3: <Unknown> at usbus2 (disconnected)
uhub_reattach_port: could not allocate new device
Trying to mount root from zfs:freenas-boot/ROOT/default []...
Mounting from zfs:freenas-boot/ROOT/default failed with error 2.
Loader variables:
vfs.root.mountfrom=zfs:freenas-boot/ROOT/default
Manual root filesystem specification:
<fstype>:<device> [options]
Mount <device> using filesystem <fstype>
and with specified (optional) option list.
eg. ufs:/dev/da0s1a
zfs:tank
cd9660:/dev/acd0 ro
(which is equivalent to: mount -t cd9660 -o ro /dev/acd0 /)
? List valid disk boot devices
. Yield 1 second (for background tasks)
<empty line> Abot manual input
mountroot>
Any ideas???
Thanks
Loader variables:
eg. ufs:/dev/da0s1a
zfs:tank
cd9660:/dev/acd0 ro
mountroot>
