I could use max 3x HDDs (WD red 10TB). So my question is is raidz1 really such a bad idea. And is a mirror a good solution/alternative. raidz2 or similar is not possible. At that system I can only use 3 drives at most.
Then a 3 drive mirror is what you want. RaidZ1 has major chances of issues with drives over 3TB and even RaidZ2 is looking unsafe by the time you get into the 10TB range.
Thanks. I agree, mirror will be the best solution. I will go with a mirror of the 2x 10TB use the third drive as a backup. I would like to keep this backup at a different location. Detaching and Attaching this third backup should work with zpool attach/detach, correct?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
