Minio says "Used: 0 bytes"
gose
I'm running the built-in "S3 Service" (aka Minio) on TrueNAS 12.0 stable. The pool is reporting 3.8Gib of space "Used" and a Compression Ratio of 2.67.
When I open the Minio UI, it says: "Used: 0 bytes"
Any pointers to resolve this?
jgreco
Resident Grinch
It would be helpful if you'd provide a little more information.
Did you store anything in it? Did you store 3.8GB of stuff and it's reporting 0?
If not, do the docs suggest that maybe there's an index database or anything that would consume some space?
gose
I have ~10TiB stored there, so compressed it's sitting at 3.8Gib on disk. I wasn't sure if the compression was tripping up Minio's reporting or something else. Just curious if others are seeing the same behavior. That would tell me it's something on my end.
