- May 28, 2011
Just loaded 9.1.1 Beta 5 as a clean install on a VM. Loaded fine. Attempting to install MiniDLNA PBI from the Plugins Screen. The plugin was installed and I configured the storage directories.
The problem, when trying to start the plugin I get the following error message below (I included a bit extra to show the installation messages). Not sure what the problem is as I didn't have this problem when testing 9.1.0RC2.
Aug 17 18:47:51 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/sbin/pbi_add -i /var/tmp/firmware/pbifile.pbi Aug 17 18:47:51 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/sbin/jexec 2 /usr/local/sbin/pbi_info -v Aug 17 18:47:51 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/sbin/jexec 2 /usr/local/sbin/pbi_add -f --no-checksig /.plugins/minidlna-1.0.25_1-amd64.pbi Aug 17 18:48:09 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/sbin/jexec 2 cat /usr/pbi/minidlna-amd64/freenas Aug 17 18:48:10 freenas notifier: Performing sanity check on nginx configuration: Aug 17 18:48:10 freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok Aug 17 18:48:10 freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful Aug 17 18:48:11 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:48:11 freenas kernel: arp: 192.168.1.30 moved from 02:e8:a8:00:08:0b to 90:a4:de:99:db:de on em0 Aug 17 18:48:13 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:48:13 freenas last message repeated 2 times Aug 17 18:48:16 freenas manage.py: [plugins.utils:80] Couldn't retrieve http://192.168.1.23/plugins/minidlna/1/_s/status: timed out Aug 17 18:48:18 freenas manage.py: [freeadmin.navtree:473] Couldn't retrieve http://192.168.1.23/plugins/minidlna/1/_s/treemenu: timed out Aug 17 18:49:27 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:49:52 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:49:52 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden set defaultrouter-ipv4 dlna_1 192.168.1.1 Aug 17 18:49:53 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:49:53 freenas last message repeated 3 times Aug 17 18:49:58 freenas manage.py: [freeadmin.navtree:473] Couldn't retrieve http://192.168.1.23/plugins/minidlna/1/_s/treemenu: timed out Aug 17 18:50:09 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:50:14 freenas manage.py: [plugins.utils:80] Couldn't retrieve http://192.168.1.23/plugins/minidlna/1/_s/status: timed out Aug 17 18:50:20 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:50:25 freenas manage.py: [plugins.utils:80] Couldn't retrieve http://192.168.1.23/plugins/minidlna/1/_s/status: timed out Aug 17 18:50:25 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Aug 17 18:50:42 freenas last message repeated 6 times Aug 17 18:50:47 freenas manage.py: [freeadmin.navtree:473] Couldn't retrieve http://192.168.1.23/plugins/minidlna/1/_s/treemenu: timed out
