bingobango
- Aug 30, 2012
Guys I have been trying to get miniDLNA setupp and working for the past few days.
I created 2 dataset as per this video: www.youtube.com/watch?v=g4zIZX8pOas
Volume Path
HOMENAS/Media /mnt/HOMENAS/Media
HOMENAS/PluginsJail /mnt/HOMENAS/PluginsJail
I was able to install the jail and used the following settings
Plugins jail path: /mnt/HOMENAS/PluginsJail
Plugin name: PluglinsJ
Jail IP: 192.168.0.12 (I just picked this, nothing else is using it)
Jail ip mask: 255.255.255.0 (got this from windows cmd ipconfig)
Plugins archive path: /mnt/HOMENAS/Media
Turned "on" the plugins and then I went to Plugins and installed the minidlna amd64 version (for version 8.2 of freenas - minidlna-1.0.22_3-amd64)
All day the miniDLNA configuration was ot appearing in the tree on the elft, but now it has appeared. I went in and added the settings and saved "successfully". When I try and turn it on I get this:
"MiniDLNA data did not validate, configure it first."
When I click on miniDLNA in the left and plugin tree - the settings are not saved? Should they be saved (like friendly name etc?)
Do you need to create a mount point also whatever that is?
I appreciate the help on this, I kow it can be frustrating helping out noobs but we all start somewhere. I have been googling this all day, the instructions are not too clear.
Volume Path
