Hi everybody,
I'm new to this Forum, I've just installed FreeNAS 9.1.1 and started to use it. I'm experiencing the same problem from praecorloth member.
If I start miniDLNA service from the GUI, it starts but cannot see any video files in WMP; if I start it manually from the command line the files appear.
Perhaps I can add something new to the discussion:
1) in the bad situation I can find errors in /var/log/minidlna.log inside the jail (substantially it says there is an error in scanning /media)
2) in my case the folder mounted to /media is in another disk; I verified that if I mount to /media a folder inside the same disk where the jail resides and start the service from the GUI then it works.
However I prefer not to use the second solution because I have used the available disks (of different sizes) in such a manner that there's a small disk where I put all the services I need (minidlna, svn, mysql, etc) and other two disks where I have movies (in one of them) and personal documents (in the other).
Finally I cannot succeed in putting the call to the minidlna service in Init/Shutdown Scripts. It does not start and I cannot find a log file with some error message about this.
Please, if you have any ideas, let me know.
P.S.: I hope my English is not too poor.
