Mailstorm
- Oct 12, 2014
Title says all. Here is the log of minidlna.log:
In jail storage, this is what I have.
Source: /mnt/STOR
Destination: /media/Video
Read only is unchecked.
Mounted? is unchecked because it wont work if checked.
MiniDLNA.conf:
Also, /mnt/STOR has about 100 some pictures and videos. So, that place isn't empty. What is going on?
PS: miniDLNA shows up on PnP devices like my phone and TV. Also, I know I spelled DLNA wrong. My fingers moved in the wrong order.
[2014/10/29 00:09:33] minidlna.c:913: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.16.1].
[2014/10/29 00:09:33] minissdp.c:108: error: bind(udp): Address already in use
[2014/10/29 00:09:33] minissdp.c:815: error: connect("/var/run/minissdpd.sock"): No such file or directory[2014/10/29 00:09:33] minidlna.c:1011: fatal: Failed to connect to MiniSSDPd. EXITING[2014/10/29 00:09:3
7] minidlna.c:913: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.16.1].
[2014/10/29 00:09:37] minidlna.c:936: warn: Creating new database...
[2014/10/29 00:09:37] minissdp.c:108: error: bind(udp): Address already in use
[2014/10/29 00:09:37] minissdp.c:815: error: connect("/var/run/minissdpd.sock"): No such file or directory[2014/10/29 00:09:37] minidlna.c:1011: fatal: Failed to connect to MiniSSDPd. EXITING[2014/10/29 00:09:3
7] scanner.c:732: warn: Scanning /media/Video
[2014/10/29 00:09:37] scanner.c:803: warn: Scanning /media/Video finished (0 files)!
[2014/10/29 00:09:37] playlist.c:126: warn: Parsing playlists...In jail storage, this is what I have.
Source: /mnt/STOR
MiniDLNA.conf:
media_dir=/media/Video port=8200 inotify=yes enable_tivo=no strict_dlna=yes notify_interval=895 friendly_name=Media model_number=00132435 serial=15
