ispybadguys
- Jul 5, 2015
I have a FreeNAS system with 4x8TB disks that I moved to SCALE. Well maybe I moved it. I upgraded to CORE and then after some confusion I did a clean install of SCALE and restored the saved configuration from CORE. Everything looked fine. under FreeNAS it was a RAID5 system and I can see the tank. I wanted to expand the capacity by replacing disks one so I pulled the first disk and replaced it with an 18TB. Reading the instructions on replacing the disks I find that the instructions do not match my SCALE GUI. I have no pools defined or at least nothing shows as a pool. I see the original tank and the disks but no Pool. It tells me to to select the icon that looks like a stack of disks but I have nothing like this. I really don't care too much about the data on this system but I don't see how to proceed.
Thanks
Kurt
Thanks
Kurt
