Peter Ewald
- Feb 15, 2017
I am new to this forum and also new to freenas. I did search for my question, but did not really find an answer.
I want to set up a FreeNas (9.2.5 or 9.3) with new 6x 4TB WD Red in Raid Z2 on a older machine: Celsius W530 with 8 core Intel Xeon 3.40GHz, 32 GB Ram and a Fujitsu D3227 board. The idea is to save the money to buy a new machine now and to do that later when the old is not working anymore. I also have an identically second machine which I could use for replacing broken parts.
I wonder, if once the hardware is broken (like the mainboard), I can migrate the Zfs Pool to another machine without a loss of data or replace a hardware piece in the current machine. In the Documentation as well as here I find the information that you should be able to do it by exporting the pool on the old machine and importing it on the new system where you set up a new freenas installation.
But when hardware stops to work I will not be able to export the pool. Is this a problem? Can you still import the data and maybe only lose latest data not written to the disks? Or will it refuse to import the pool?
Do you think I should rather buy a complete new system than only new disks?
Please tell me, if you need more information. Thanks a lot.
