Right now the focus is on getting SCALE to RELEASE quality.... manual migrations are possible, but we don't yet want to encourage mass sidegrades. THe quality of CORE is still significantly higher than SCALE. So, tools are still not available.Hello,
I thought I would follow up on this.
Are there already migration tools available?
Allright, then I will play the waiting game, and wait for scale to release.Right now the focus is on getting SCALE to RELEASE quality.... manual migrations are possible, but we don't yet want to encourage mass sidegrades. THe quality of CORE is still significantly higher than SCALE. So, tools are still not available.
I ended up backing up the CORE VMs using Clonezilla, recreating the VMs in SCALE and restoring the Clonezilla images. Seems to have worked fine.Allright, then I will play the waiting game, and wait for scale to release.
Thank you for the update :)
Could you elaborate on the steps you took or point to a guide you may have followed? ThanksI ended up backing up the CORE VMs using Clonezilla, recreating the VMs in SCALE and restoring the Clonezilla images. Seems to have worked fine.
This is a standard way to migrate between hypervisors. Wright down the VM definitions. Create backup or image. Define VM on new hypervisor using the values you recorded. Boot the rescue media from an ISO mounted on the virtual DVD rom drive. Restore, remove virtual media from DVD. Reboot. If windows, deal with activation issues. Other applications may also scream.Could you elaborate on the steps you took or point to a guide you may have followed? Thanks
Exactly as Morris said.Could you elaborate on the steps you took or point to a guide you may have followed? Thanks
