WattsUp314
- Jan 24, 2019
After a sudden power loss (wind storm induced) my server fails to boot up. It lets me drop into the shell physically, network interfaces are down. It cites middleware failing to start. Below is the log output, this message repeats every 6 seconds for the entire log. Any ideas why? Or should I just reinstall and reupload the configuration file?
middlewared.log
middlewared.log
[2021/11/16 17:22:05] (INFO) middlewared.__init__():851 - Starting TrueNAS-SCALE-22.02-MASTER-20211111-192922 middleware
[2021/11/16 17:22:13] (DEBUG) middlewared.setup():1895 - Timezone set to America/Los_Angeles
[2021/11/16 17:22:13] (INFO) UserService.sync_builtin():111 - Creating new group 'minio'
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1276, in _execute_context
self.dialect.do_execute(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/default.py", line 609, in do_execute
cursor.execute(statement, parameters)
sqlite3.IntegrityError: UNIQUE constraint failed: account_bsdgroups.bsdgrp_group
The above exception was the direct cause of the following exception:
File "/usr/bin/middlewared", line 12, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1749, in main
Middleware(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1576, in run
self.loop.run_until_complete(self.__initialize())
File "/usr/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete
return future.result()
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1641, in __initialize
await self.__plugins_setup(setup_funcs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 968, in __plugins_setup
await call
File "/usr/lib/python3/dist-packages/middlewared/plugins/account.py", line 1581, in setup
await middleware.call('user.sync_builtin')
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1310, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1278, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1180, in run_in_executor
return await loop.run_in_executor(exc, functools.partial(method, *args, **kwargs))
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/account_/sync_builtin.py", line 121, in sync_builtin
existing_group["id"] = self.middleware.call_sync(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1326, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1366, in run_coroutine
return fut.result()
File "/usr/lib/python3.9/concurrent/futures/_base.py", line 433, in result
return self.__get_result()
File "/usr/lib/python3.9/concurrent/futures/_base.py", line 389, in __get_result
raise self._exception
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1269, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/write.py", line 41, in insert
result = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/connection.py", line 70, in execute_write
return await self.middleware.run_in_executor(self.thread_pool, self._execute_write, sql, binds, options)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1182, in run_in_executor
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/connection.py", line 73, in _execute_write
result = self.connection.execute(sql, binds)
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1003, in execute
return self._execute_text(object_, multiparams, params)
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1172, in _execute_text
ret = self._execute_context(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1316, in _execute_context
self._handle_dbapi_exception(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1510, in _handle_dbapi_exception
util.raise_(
File "/usr/lib/python3/dist-packages/sqlalchemy/util/compat.py", line 182, in raise_
raise exception
sqlalchemy.exc.IntegrityError: (sqlite3.IntegrityError) UNIQUE constraint failed: account_bsdgroups.bsdgrp_group
[SQL: INSERT INTO account_bsdgroups (bsdgrp_gid, bsdgrp_group, bsdgrp_builtin, bsdgrp_sudo, bsdgrp_sudo_nopasswd, bsdgrp_sudo_commands, bsdgrp_smb) VALUES (?, ?, ?, ?, ?, ?, ?)]
[parameters: (473, 'minio', 1, 0, 0, '[]', 0)]
(Background on this error at: http://sqlalche.me/e/13/gkpj)
