KristijanL
- Jun 28, 2013
I am running SCALE BETA for a while now, without any issues, but todays upgrade to RC1 failed with "Failed to start TrueNAS Middleware" on boot, and after a while i was dropped to shell. So i thought there was some issue with an update, so i did a fresh install with the same result. I am attaching my whole log folder of fresh install.
any pointers what to check?
Manufacturer: Supermicro
Product Name: X9DRD-7LN4F(-JBOD)/X9DRD-EF
Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
2021/11/10 14:48:48] (DEBUG) middlewared.setup():1882 - Timezone set to America/Los_Angeles Traceback (most recent call last): File "/usr/bin/middlewared", line 12, in <module> sys.exit(main()) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1749, in main Middleware( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1576, in run self.loop.run_until_complete(self.__initialize()) File "/usr/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete return future.result() File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1641, in __initialize await self.__plugins_setup(setup_funcs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 968, in __plugins_setup await call File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 1168, in setup await middleware.call("alert.initialize") File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1310, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 219, in initialize is_enterprise = await self.middleware.call("system.is_enterprise") File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1310, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/system.py", line 541, in is_enterprise return await self.middleware.call('system.product_type') in ['ENTERPRISE', 'SCALE_ENTERPRISE'] File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1310, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1263, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1131, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/system.py", line 525, in product_type hardware = await self.middleware.call('failover.hardware') File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1310, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1263, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1131, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/failover.py", line 204, in hardware return (await self.middleware.call('failover.ha_mode'))[0] File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1310, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/failover.py", line 187, in ha_mode FailoverService.HA_MODE = await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1310, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1278, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1180, in run_in_executor return await loop.run_in_executor(exc, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/failover_/detect_enclosure.py", line 21, in detect manufacturer = self.middleware.call_sync('system.dmidecode_info')['system-product-name'] File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1334, in call_sync return self.run_coroutine(self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args)) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1366, in run_coroutine return fut.result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 433, in result return self.__get_result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 389, in __get_result raise self._exception File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1180, in run_in_executor return await loop.run_in_executor(exc, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/system_/dmi.py", line 22, in dmidecode_info self._parse_dmi(cp.stdout.splitlines()) File "/usr/lib/python3/dist-packages/middlewared/plugins/system_/dmi.py", line 40, in _parse_dmi sect, val = [i.strip() for i in line.split(':')] ValueError: too many values to unpack (expected 2)
