Mellanox Connectx-4 Lx 25Gb NIC Not Loading
akc1
Hoping somebody more knowledgeable than myself can help me with this issue please.
I have a virtualised TrueNAS-12.0-U2.1 on ESXi 7 and am passing through a Mellanox Connectx-4 Lx 25Gb NIC. I can see that TrueNAS is trying to load the NIC but failing. below is the output of dmesg | grep mlx
mlx5en: Mellanox Ethernet driver 3.5.2 (September 2019) mlx5_core0: <mlx5_core> mem 0xe7a00000-0xe7afffff at device 0.0 on pci4 mlx5_core0: ERR: mlx5_init_once:939:(pid 0): Unable to find vendor specific capabilities mlx5_core0: ERR: mlx5_load_one:1121:(pid 0): enable msix failed mlx5_core0: ERR: init_one:1605:(pid 0): mlx5_load_one failed -6 device_attach: mlx5_core0 attach returned 6 mlx5_core0: <mlx5_core> mem 0xe7a00000-0xe7afffff at device 0.0 on pci4 mlx5_core0: ERR: mlx5_init_once:939:(pid 85): Unable to find vendor specific capabilities mlx5_core0: ERR: mlx5_load_one:1121:(pid 85): enable msix failed mlx5_core0: ERR: init_one:1605:(pid 85): mlx5_load_one failed -6 device_attach: mlx5_core0 attach returned 6 mlx5_core0: <mlx5_core> mem 0xe7a00000-0xe7afffff at device 0.0 on pci4 mlx5_core0: ERR: mlx5_init_once:939:(pid 711): Unable to find vendor specific capabilities mlx5_core0: ERR: mlx5_load_one:1121:(pid 711): enable msix failed mlx5_core0: ERR: init_one:1605:(pid 711): mlx5_load_one failed -6 device_attach: mlx5_core0 attach returned 6
If anyone has any ideas they would be gratefully received!
Thank you
Alex
Patrick M. Hausen
Are there APIC specific parameters in your VM configuration that you could tweak?
Could you boot TrueNAS on the bare metal?
akc1
Hello Patrick
Thanks for your help, not sure about APIC parameters(do you know a good resource to learn?). I experience the same issue with bare metal
Patrick M. Hausen
I just googled your type of card and "FreeBSD". Some people seem to get similar errors based on whether "x2apic" is enabled or not. I'd just look at the VM parameters for something by the name of "APIC mode" or similar and try if that changes anything.
Apart from that, no clue. Sorry.
akc1
Thank you Patrick I will investigate.
