failed to start BCM5720 network interface in TrueNAS CORE 12.0-U6.1
ldfandian
I installed TrueNAS CORE VM of the latest version (12.0-U6.1), on my HPE ML110 Gen10 server (with HPE customized VMware ESXI 7.0U2).
I could do PCI passthrough the embedded NIC (NetXtreme BCM5720 Gigabit Ethernet) successfully, but it failed to start in TrueNAS system.
Do I need some special network driver for it ?
(To ensure it is not a cable issue, I also tried mount the same PCI passthrough NIC into another ubuntu VM on the same ESXI box, it works like a charm. So, it should not be an issue on the ESXI side)
Any feedbacks are appreciated.
root@truenas[~]# pciconf -lv | grep -B4 network
subclass = SATA
vmx0@pci0:3:0:0: class=0x020000 card=0x07b015ad chip=0x07b015ad rev=0x01 hdr=0x00
vendor = 'VMware'
device = 'VMXNET3 Ethernet Controller'
class = network
subclass = ethernet
none1@pci0:11:0:0: class=0x020000 card=0x22e8103c chip=0x165f14e4 rev=0x00 hdr=0x00
vendor = 'Broadcom Inc. and subsidiaries'
device = 'NetXtreme BCM5720 2-port Gigabit Ethernet PCIe'
class = network
root@truenas[~]#
root@truenas[~]# ifconfig
vmx0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=e403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:0c:29:dc:29:8a
inet 192.168.9.20 netmask 0xffffff00 broadcast 192.168.9.255
media: Ethernet autoselect
status: active
nd6 options=1<PERFORMNUD>
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
root@truenas[~]# dmesg
ge0: <HPE Ethernet 1Gb 2-port 332i Adapter, ASIC rev. 0x5720000> mem 0xe7ad0000-0xe7adffff,0xe7ae0000-0xe7aeffff,0xe7af0000-0xe7afffff irq 16 at device 0.0 on pci4
bge0: APE FW version: NCSI v1.5.18.0
bge0: CHIP ID 0x05720000; ASIC REV 0x5720; CHIP REV 0x57200; PCI-E
bge0: APE lock 1 request failed! request = 0x8404[0x1000], status = 0x8424[0x0000]
bge0: APE lock 4 request failed! request = 0x8410[0x1000], status = 0x8430[0x0000]
bge0: APE lock 0 request failed! request = 0x8400[0x1000], status = 0x8420[0x0000]
bge0: Try again
bge0: Try again
bge0: Try again
bge0: Try again
bge0: attaching PHYs failed
device_attach: bge0 attach returned 6
jgreco
Resident Grinch
The Broadcom chips often have sorta flaky drivers. You are additionally trying to add another layer of complexity on top, in the form of PCI passthru. I am not particularly shocked it doesn't work. This would be much more likely to work with the Intel ethernet chips.
ldfandian
Thanks, I chose to use virtual network instead... Neverthanless, it should be 90+% performance of PCI passthrough, it should be OK for me.
