Mellanox Connectx-2 with FreeNAS 11
ibmguy
I just got in a Mellanox Connectx-2 card and put it into my FreeNAS server.
I have been unsuccessful at getting it to work.
FreeNAS is able to see the card and i am able to see it in the command line network configuration of FreeNAS.
When I set it as the default nic and give it a static ip address it does not come through.
any ideas.
ibmguy
Post the output of ifconfig within code tags.
bce0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=c01bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,VLAN_HWTSO,LINKSTATE>
		ether e4:1f:13:b7:71:3c
		media: Ethernet autoselect
bce1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=c00b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
		ether e4:1f:13:b7:71:3e
		inet 10.1.10.20 netmask 0xffffff00 broadcast 10.1.10.255
		media: Ethernet autoselect (1000baseT <full-duplex>)
		status: active
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
		groups: lo
mlxen0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=ed07bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,LINKSTATE,
		ether e4:1d:2d:68:ff:3e
		media: Ethernet autoselect (10Gbase-SR <full-duplex,rxpause,txpause>)
		status: active
ue0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
		ether e6:1f:13:aa:71:3f
		ether 02:8a:2f:ed:33:00
		nd6 options=1<PERFORMNUD>
		groups: bridge
		member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 7 priority 128 path cost 2000
		member: bce1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 2 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:ff:20:00:07:0a
		status: active
		groups: epair
DrKK
FreeNAS Generalissimo
I'm not sure what motherboard you're using, but I can tell since it has a BCE0 on it, none of us will approve. :)
Anyway:
Looks like bce1 is apparently active, and connected. With something plugged in. Looks like mlxen0 is plugged in, and connected, but not active (NB: I am using "active" in a more colloquial sense, not the way it is meant in "ifconfig"). I suggest you physically go to this console (which of course, this is not a console, this is some non-server rig), but whatever, physically go to the box, with local keyboard and monitor, and DISABLE the bce1 in the console menu. *THEN* enable the mellanox as the default NIC with static IP. 98% sure this is your problem.
You see, I don't think if the system is already configured to use NIC X, then you can just enable NIC Y and it will cycle off NIC X and go to NIC Y, which is what I think you are assuming. You must first explicitly release NIC X, which you cannot do unless you are physically at the computer (you can't release the NIC you're remotely using to talk to the server, right?).
ibmguy
Anyway:
The server is a IBM x3650 m3 with dual 16 core xeons 48Gb ram and 16 900Gb WD XE gen 2 sas drives. The switch i am using is a ubiquiti US‑16‑XG.
I went into the IBM IMM and started a KVM client and rest the bce1 from the menu and set up the mellanox with a static..
if i try to set up the mellanox with dhcp it does not get an ip address either.
what should i do in this menu.
Thanks
ibmguy
at this point i have tried multiple card in different pcie ports... the server sees the card and i am able to give it a static ip and configure it.. i have noticed on the switch it sees that something is plugged in put does not see any data. maybe a driver issue. maybe need to compile a driver for the card?
ibmguy
Problem solved. Turnes out one of the 10gb DAC cables is bad. Swapped out and working fine
Oldtimer
I just got in a Mellanox Connectx-2 card and put it into my FreeNAS server which is seen by the Freenas server.
I have been unsuccessful to a connection on the 10gbe.
I can ping my windows machine in a peer to peer configuration and vice versa.
The reason I got the Mellanox 10gbe adapters was after watching a Youtube video. (https://youtu.be/8f5cuzcNrLo)
Admittedly the video shows the adapter working Freenas Corral.
I went the HCL and to my horror, my current NIC isn't listed.
IPs used are 192.168.240 for the onboard 1Gbe NIC and 192.168.200.1 both on subnet 255.255.255.0
Oldtimer
FreeBSD 11.0-STABLE (FreeNAS.amd64) #0 r313908+d7d07647f69(freenas/11.0-stable): Thu Jul 20 19:01:05 UTC 2017
  FreeNAS (c) 2009-2017, The FreeNAS Development Team
  All rights reserved.
  FreeNAS is released under the modified BSD license.
  For more information, documentation, help or support, go here:
  http://freenas.org
Welcome to FreeNAS
root@freenas:~ # ifconfig
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
  ether 0c:c4:7a:6b:60:7c
  inet 192.168.1.240 netmask 0xffffff00 broadcast 192.168.1.255
  status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
  options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
  ether 0c:c4:7a:6b:60:7d
  status: no carrier
  groups: lo
mlxen0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=ed07bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
  ether 00:02:c9:52:b8:50
  inet 192.168.200.1 netmask 0xffffff00 broadcast 192.168.200.255
  status: active
bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
  ether 02:96:bb:d5:4b:00
  groups: bridge
  member: epair5a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
  ifmaxaddr 0 port 11 priority 128 path cost 2000
  member: epair4a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
  ifmaxaddr 0 port 10 priority 128 path cost 2000
  member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
  ifmaxaddr 0 port 9 priority 128 path cost 2000
  member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
  ifmaxaddr 0 port 8 priority 128 path cost 2000
  member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
  ifmaxaddr 0 port 6 priority 128 path cost 2000
  member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
  ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=8<VLAN_MTU>
  ether 02:ff:e0:00:06:0a
  status: active
  groups: epair
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=8<VLAN_MTU>
  ether 02:ff:e0:00:07:0a
  status: active
  groups: epair
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=8<VLAN_MTU>
  ether 02:ff:e0:00:08:0a
  status: active
  groups: epair
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=8<VLAN_MTU>
  ether 02:ff:e0:00:09:0a
  status: active
  groups: epair
epair4a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=8<VLAN_MTU>
  ether 02:ff:e0:00:0a:0a
  status: active
  groups: epair
epair5a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
  options=8<VLAN_MTU>
  ether 02:ff:e0:00:0b:0a
  status: active
  groups: epair
root@freenas:~ #
ibmguy
what switch and sfp+ transmitters are you using?
Oldtimer
No Switch ibmguy.
This is on a peer to peer setup. using ip address 192.168.200.1 on the NAS and ip address 192.168.200.2 on the pc,
using a 3M SFP+ cable as the link.
I have done so many changes I am at a total lost regarding this setup.
What are your steps in assiging 10gbe adapter to the nic in which I can transfer files through?
ibmguy
No Switch ibmguy.
Unfortunately i am not failure with the peer to peer set up with the connect x2...
I had much luck using the ubiquiti US‑16‑XG... besides my cable being bad.
are you using sfp+ dac or sfp+ fiber transmitters?
Oldtimer
I am using sfp+ dac.
Your setup makes me drool
I am trying to locate a pair of Chelsio adapters. My search for the answers has been futile thus far.
Spearfoot
He of the long foot
You said you can successfully ping the FreeNAS server IP address from the PC and vice versa... have you bound the FreeNAS SMB service to the 10G IP address? It may only be bound to your 1G connection.
Oldtimer
Firstly I am transfering data over the peer-to peer link.
My transfers speeds are slightly over the 1G rate.
The C drive a Corsair SSD. 240Gb, the other two CDM images are the Freenas shares 1Gb(X:/) and 10Gb.(Y:/)
My main pc is so mediocre. CPU FX6300,
Asus M5A97 R2.0 Motherboard (AMD 970/SB950, 4x DDR3, S-ATA 600, ATX, PCI-Express 2.0, USB 3.0, USB BIOS Flashback,
8Gb of Corsair Ram and older Sata 2 drives.
Spearfoot
He of the long foot
My main pc is so mediocre. CPU FX6300, MB Asus m97 R2.0 8Gb of Corsair Ram and older Sata 2 drives.
So, it's working and you no longer have a problem?
Oldtimer
