mDNS Announcements for _adisk._tcp
joltman
I'm trying to configure a Time Machine share. I've followed the guide, however I'm still not seeing mDNS announcements from FreeNAS for _adisk._tcp.local. I was under the impression from the doc that when you check TIME MACHINE on the share, that this will "enable" these mDNS annoucements. I'm only seeing _smb._tcp.local announcements from FreeNAS. Also, from asking on the IRC channel, I'm supposed to enable vfs_fruit on all SMB shares otherwise the Macs will never see the _adisk._tcp.local announcement? I'm not seeing that listed in the guide specifically. I can enable that, but I don't know what the syntax of the AUXILIARY PARAMETERS are. Is it a new parameter on each line, or do I have to throw a comma in between parameters? Here's what I currently have on my Time Machine Share:
fruit:time machine max size = 1 T
vfs_fruit
I'd really like to get this working. Thanks for the help!
joltman
OK, so I did some more poking around, and I think I was supposed to enable the "VFS Object" named "fruit". I've done that on all my SMB shares, but I'm still not seeing _adisk._tcp.local announcements. I'm seeing MANY more announcements from the NAS, more than before I did this.
anodos
Sambassador
If you check "time machine", then fruit will be automatically added to all shares when the smb.conf is generated. The _adisk._tcp. advertisements /registration are generated by the parent smbd process when it starts. This means that after configuring a time machine share, you will need to restart the SMB server. I think 11.2 U7 will and 11.3-Beta-1 prompts to restart the SMB service after configuring a time machine share. Automatically restarting services on share configuration changes is usually a bad idea and so we leave it up to the admin to choose whether to do this.
joltman
Anodos:
Thank you for responding! So, should I remove my fruit entry from all VFS Objects, or leave it in? And I never saw a mention of restarting the service in the docs, but thank you for telling me about it! I'll give it a shot.
joltman
Anodos:
OK, so there's no button in the GUI to restart the SMB service, so I went to the CLI and issued:
service samba_server restart
This restarted the service and now I'm seeing _adisk._tcp.local being announced! Huzzah!!
As part of my config, I've got my FreeNAS sitting in a different SUBNET than my LAN and WLAN clients. In order to have these mDNS announcements travel across VLANs, I had to configure Cisco's Service Routing feature. I'm running two Cisco 3750X switches in a stack. They're acting as my core switches and have VLAN interfaces for all my VLANs (LAN, WLAN, Servers, Phones, Media). I have a pfSense router above this and I'm using OSPF between the two devices. I've got a GUEST VLAN, but the interface doesn't land on the switch stack, it lands on the pfSense device. Here's my config that's allowing mDNS annoucements to cross VLANs.
ip multicast-routing distributed
service-routing mdns-sd
service-list mdns-sd REDISTRIBUTE-MDNS permit 10
  match message-type query
service-list mdns-sd REDISTRIBUTE-MDNS permit 20
  match message-type announcement
  match service-type _googlecast._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS permit 30
  match service-type _googlerpc._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS permit 40
  match service-type _googlezone._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS permit 50
  match service-type _airplay._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS permit 60
  match service-type _raop._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS permit 70
  match service-type _adisk._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS permit 80
  match service-type _smb._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS permit 90
  match service-type _airport._tcp.local
service-list mdns-sd REDISTRIBUTE-MDNS deny 100
service-list mdns-sd QUERY-MDNS permit 10
service-list mdns-sd QUERY-MDNS deny 20
service-list mdns-sd PERMIT-ALL permit 10
service-list mdns-sd ACTIVE-QUERY-CHROMECASTS query
! Test out mDNS service discovery by permitting ALL mDNS:
interface vlan10
    service-policy PERMIT-ALL IN
    service-policy PERMIT-ALL OUT
    service-policy-query ACTIVE-QUERY-CHROMECASTS 110
    redistribute mdns-sd
ip pim sparse-dense-mode
interface vlan12
interface vlan666
interface vlan19
interface vlan20
! Implement locked down mDNS
interface vlan10
    service-policy QUERY-MDNS IN
interface vlan12
interface vlan666
interface vlan19
    service-policy REDISTRIBUTE-MDNS IN
interface vlan20
For now, I'm using the PERMIT-ALL access list to allow all mDNS announcements/queries to cross VLAN boundaries. When I get this working a bit better, I'll lock this down more.
