purduephotog
- Jan 14, 2013
It's been a very long week and I normally wouldn't consider begging for help, but here I am.
I have one completely stable build using 9.2.1.8 and it fired right up after being down a year (for my medical reasons).
I purchased similar hardware except for the Viking ram, given the changes, and now I have a board that just looks ... odd... compared to every other supermicro build I've done.
Basically, the standby power LED (orange) is glowing, but instead of the solid blinky green LED I get ... a very very dim LED barely lit. The machine won't turn on, period. I've shorted the jumpers directly (assuming a bad connection) and it still won't come on.
I can fire up another mobo with the PSU, so I doubt its that but I will be swapping out.
It's a G3220, MBD-X10SLL-F-O, Samsung 8GB DDR3-1600 MHz PC3-12800 240-pin ECC Server Memory - M391B1G73QH0-YK0.
It ought to turn on or spin a fan or beep at me. It doesn't.
I've pulled out all the peripherals and dropped the board back onto a static mat and still no go.
Before I rip down the working FreeNas build and steal the Viking Ram (which may or may not even work) ... is there something I should try first? Because frankly I'm out of ideas...
... pulled CMOS batter, reset bios, watchdog on/off, IPMI on/off,USB stick in / out....
