This is my first build using X10SLL-F-O and Pentium G3220. I plugged everything in and when I turn on the power supply, I see a solid orange LED and a blinking green LED on the motherboard. According to the manual, both are indicating normal status (AC power is connected and BMC Heartbeat respectively). Now if I try to turn on the power switch on the case, nothing happens.
I removed all peripherals, USB and fan connectors, RAM and hard drives and still not turning on. I even took it out of the case to rule out shorting, removed the CPU 4pin connector leaving only the CPU, CPU fan, and 24pin connector. I tried to power it on using a screwdriver to short the power headers. Still, it doesn't turn on but the LEDs are still on.
