I am having some trouble with Freenas performance. Making a copy of a 350MB File through CIFS in the same network directory results in 3.16MB/s.
Also copying files from my workstation over to the NAS only runs at a rate of 6MB/s write and 18MB/s read.
Everything is hooked up through gigabit switch. In case this matters - the zfs Volume is a Mirror of 2 HDDs, WDVelociraptor 10k rpm and SamsungSpinpoint 7.2k rpm (this only a testing setup, WDReds are ordered).
So there definitely is something wrong with my setup in terms of performance, generally speaking, but the fact that making a file copy on the NAS is that slow and even slower than transferring a file from workstation to NAS, leaves me clueless.
ifconfig output:
system specs:
ifconfig output:
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether d0:50:99:83:46:88
inet 192.168.178.28 netmask 0xffffff00 broadcast 192.168.178.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>system specs:
NAS Box: Workstation: OS: Freenas 9.3 OS: Windows 7 BOARD: ASRock N3700-ITX BOARD: Asus x99-Deluxe CPU: Intel Pentium N3700 CPU: Intel i7-5960X NIC: Realtek L8111GR (onboard) NIC: Intel I218V (onboard) RAM: 16GB (NON-ECC) RAM: 32GB Network Hardware: Switch: Netgear GS105 (5-Port Gigabit) Router: AVM FRITZ!Box 3490 Network Infrastructure: [Router]->[Switch]->[Nas Box, Workstation]
