Jails created with bridge1, no physical interfaces
shpokas
Hi there,
my NAS already has bridge0, for openvpn.
Why my jails, created vith VIMAGE option, are bridged to bridge1 which has no physical interfaces?
Full ifconfig output below. Note bridge1 has only one member, epair0a.
Is there a way to have only one bridge, bridge0?
Thanks for your time,
shpokas
$ ifconfig
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether a0:1d:48:c7:ca:94
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
bge1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
ether 02:c0:75:36:94:00
inet 192.168.150.20 netmask 0xffffff00 broadcast 192.168.17.255
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000000
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 20000
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
status: active
laggproto lacp lagghash l2,l3,l4
laggport: bge1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: bge0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=80000<LINKSTATE>
ether 00:bd:f6:a5:00:00
status: active
Opened by PID 3095
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 02:c0:75:36:94:01
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:59:24:00:0c:0a
status: active
The short answer is that if a bridge already exists for something else it isn't used. So no, you can't.
shpokas
Thanks for answer.
Well... because I have two physical interfaces, would it be possible to use bge0 for jail bridge and bge1 for openvpn?
To put it differently - is it possible to run openvpn in bridge mode and jails with VIMAGE option set on the same box?
Not really. FreeNAS was never designed to act as a VPN, so not surprisingly it isn't "totally trivial" to do. The jails are basically made available to the entire system(and all networks they are attached to). There's no easy fix without setting up multiple subnets.
This is one of *many* reasons why VPN functions with FreeNAS are just "a bad idea". Never mind the security implications that could result.
shpokas
No, it's not a bad idea. It's just a FreeNAS limitation.
Thanks for answers though.
I could hack around if only I know where to start.
Sorry, but you are very very wrong about that. There's about 50 threads on the topic if you want to understand the reasons why more definitively.
shpokas
I certainly do not want to start a flame war, not even a discussion.
Just noting that if I could afford or wish to use multiple single purpose boxes then I'd do so. There are always arguments why one should not put all eggs in one basket, BUT... I have small business with HP Microserver and I need to pack all in that box.
Putting VPN on ARM based router just doesn't cut if you have 100 Mb line. I do not have another box for VPN.
Thanks for your informative response.
A business that can't do a VPN correctly?!
I'm glad I don't use use for whatever service you use. VPN on a FreeNAS box is wholly inappropriate for business use.
But good luck to you!
depasseg
FreeNAS Replicant
Actually a VPN within FreeNAS is something I'm looking into. It would make replication between FreeNAS's very powerful. Something like neorouter would allow easy deployment and work through firewalls. I'm only looking for the VPN connection to go to other FreeNAS's, not to be a client endpoint.
Let me know if you make any progress.
You should read up on FreeNAS' replication then. It uses the SSH tunnel, which for all intents and purposes, provides at least the same level of security as a VPN, with the advantage of the SSH tunnel directly supporting the ZFS replication data stream in FreeNAS.
In short, no, you don't need to use a VPN for what you want to do. You just need to use the already built-in features of ZFS replication and setup your firewalls appropriately. ;)
depasseg
FreeNAS Replicant
I absolutely have been reading up on replication, and that is exactly what I want to do. :smile:
However, I would prefer not to have to configure Dynamic DNS and port forwarding on friends/families routers for SSH to work through them.
So something like a NeoRouter VPN (which is like Hamachi before being bought by LogMeIn). Not because I need a connection, but because it easily works through remote firewalls.
The way I see it, there are 2 choices:
A: Configure a dynamic DNS client on the remote freenases, configure port-forwarding on the remote router and use replication over SSH
B: Configure NeoRouter on each FreeNas to join the same VPN network, perform replication over that.
