iocage issue with update to 11.2
Jeff Lamer
Hi All,
Apologizes for posting in two threads. We ran out of solutions in the other thread.
I updated to 11.2 and then tried to convert my warden jail to iocage and now have the following error.
Error: concurrent.futures.process._RemoteTraceback:
  File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
	r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
	res = loop.run_until_complete(coro)
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
	return future.result()
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
	return await self._call(f'{service_name}.{methodserviceobj, methodobj, params=args, job=job)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
	return methodobj(*params)
  File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
	return f(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 541, in start
	iocage.start()
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1628, in start
	callback=self.callback
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
	self.__start_jail__()
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 503, in __start_jail__
	_callback=self.callback)
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit
	_callback(content, exception)
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
	raise callback_exception(message)
RuntimeError:
Stopped sabnzbd_1 due to VNET failure
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
	result = await self.middleware.call_method(self, message)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method
	return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call
	return await self._call_worker(serviceobj, name, *args)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker
	job,
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc
	return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor
RuntimeError:
Config.json
 "CONFIG_VERSION": "14",
   "allow_chflags": "0",
   "allow_mlock": "0",
   "allow_mount": "0",
   "allow_mount_devfs": "0",
   "allow_mount_nullfs": "0",
   "allow_mount_procfs": "0",
   "allow_mount_tmpfs": "0",
   "allow_mount_zfs": "0",
   "allow_quotas": "0",
   "allow_raw_sockets": "1",
   "allow_set_hostname": "1",
   "allow_socket_af": "0",
   "allow_sysvipc": "0",
   "allow_tun": "0",
   "available": "readonly",
   "basejail": "no",
   "boot": "on",
   "bpf": "no",
   "children_max": "0",
   "cloned_release": "EMPTY",
   "comment": "none",
   "compression": "lz4",
   "compressratio": "readonly",
   "coredumpsize": "off",
   "count": "1",
   "cpuset": "off",
   "cputime": "off",
   "datasize": "off",
   "dedup": "off",
   "defaultrouter": "none",
   "defaultrouter6": "none",
   "depends": "none",
   "devfs_ruleset": "4",
   "dhcp": "off",
   "enforce_statfs": "2",
   "exec_clean": "1",
   "exec_fib": "0",
   "exec_jail_user": "root",
   "exec_poststart": "/usr/bin/true",
   "exec_poststop": "/usr/bin/true",
   "exec_prestart": "/usr/bin/true",
   "exec_prestop": "/usr/bin/true",
   "exec_start": "/bin/sh /etc/rc",
   "exec_stop": "/bin/sh /etc/rc.shutdown",
   "exec_system_jail_user": "0",
   "exec_system_user": "root",
   "exec_timeout": "60",
   "host_domainname": "none",
   "host_hostname": "sabnzbd_1",
   "host_hostuuid": "sabnzbd_1",
   "host_time": "yes",
   "hostid": "00000000-0000-0000-0000-0CC47A693206",
   "hostid_strict_check": "off",
   "interfaces": "vnet0:bridge0",
   "ip4": "new",
   "ip4_addr": "vnet0|192.168.1.3/24",
   "ip4_saddrsel": "1",
   "ip6": "new",
   "ip6_addr": "none",
   "ip6_saddrsel": "1",
   "jail_zfs": "off",
   "jail_zfs_dataset": "iocage/jails/sabnzbd_1/data",
   "jail_zfs_mountpoint": "none",
   "last_started": "none",
   "login_flags": "-f root",
   "mac_prefix": "02ff60",
   "maxproc": "off",
   "memorylocked": "off",
   "memoryuse": "off",
   "mount_devfs": "1",
   "mount_fdescfs": "1",
   "mount_linprocfs": "0",
   "mount_procfs": "0",
   "mountpoint": "readonly",
   "msgqqueued": "off",
   "msgqsize": "off",
   "nmsgq": "off",
   "notes": "warden_id=2",
   "nsemop": "off",
   "nshm": "off",
   "nthr": "off",
   "openfiles": "off",
   "origin": "readonly",
   "owner": "root",
   "pcpu": "off",
   "priority": "99",
   "pseudoterminals": "off",
   "quota": "none",
   "release": "9.3-RELEASE",
   "reservation": "none",
   "resolver": "/etc/resolv.conf",
   "rlimits": "off",
   "securelevel": "2",
   "shmsize": "off",
   "stacksize": "off",
   "stop_timeout": "30",
   "swapuse": "off",
   "sync_state": "none",
   "sync_target": "none",
   "sync_tgt_zpool": "none",
   "sysvmsg": "new",
   "sysvsem": "new",
   "sysvshm": "new",
   "template": "no",
   "type": "jail",
   "used": "readonly",
   "vmemoryuse": "off",
   "vnet": "on",
   "vnet0_mac": "02837e000a0b 02837e000a0c",
   "vnet1_mac": "none",
   "vnet2_mac": "none",
   "vnet3_mac": "none",
   "vnet_default_interface": "none",
   "vnet_interfaces": "none",
   "wallclock": "off"
ifconfig
root@freenas:~ # ifconfig
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	   options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
	   ether 0c:c4:7a:69:32:06
	   hwaddr 0c:c4:7a:69:32:06
	   inet 192.168.1.106 netmask 0xffffff00 broadcast 192.168.1.255
	   media: Ethernet autoselect (1000baseT <full-duplex>)
	   status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
	   options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
	   ether 0c:c4:7a:69:32:07
	   hwaddr 0c:c4:7a:69:32:07
	   status: no carrier
	   options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	   inet6 ::1 prefixlen 128
	   inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
	   groups: lo
	   ether 02:67:ee:c8:3f:00
	   nd6 options=1<PERFORMNUD>
	   groups: bridge
	   member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			   ifmaxaddr 0 port 8 priority 128 path cost 2000
	   member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			   ifmaxaddr 0 port 6 priority 128 path cost 2000
	   member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			   ifmaxaddr 0 port 5 priority 128 path cost 2000
	   member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			   ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	   options=8<VLAN_MTU>
	   ether 02:0c:d0:00:05:0a
	   hwaddr 02:0c:d0:00:05:0a
	   status: active
	   groups: epair
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	   description: associated with jail: sabnzbd_1
	   options=8<VLAN_MTU>
	   ether 02:83:7e:00:0a:0b
	   hwaddr 02:0c:d0:00:06:0a
	   status: active
	   groups: epair
epair0b: flags=8842<BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	   options=8<VLAN_MTU>
	   ether 02:83:7e:00:0a:0c
	   hwaddr 02:0c:d0:00:07:0b
	   status: active
vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	   options=8<VLAN_MTU>
	   hwaddr 02:0c:d0:00:08:0a
	   status: active
	   groups: epair
D
dlavigne
Guest
Which exact build version? There were some fixes to that migration script but we can't tell if you have them without knowing the version.
Jeff Lamer
I believe I was on 11.1 u6 stable and updated to 11.2 stable. I just ran it on this past Saturday
Thanks
Jeff Lamer
D
dlavigne
Guest
Thank you. Since that is the latest and I don't see an open ticket for that particular traceback, please create a report at bugs.freenas.org and post the issue number here.
Jeff Lamer
First time reporting a bug.
Issue #54351 created.
Jeff Lamer
Ok, still trying (testing) to resolve this issue.
It tried the following;
Configure jail’s default gateway
# iocage set defaultrouter=192.168.1.1 sabnzbd_1
Configure an IP address
iocage set ip4_addr="vnet0|192.168.1.103/24" sabnzbd_1
Start jail and ping the default gateway
Start the jail:
# iocage start sabnzbd_1
The jail did start which I think is a success. Now....how do I see my plugins? as they aren't showing up and won't load in my browser.
