No Network interface created in new iocage jail
jgdempsey
I'm working on setting up a Transmission jail with OpenVPN. I'm on FreeNAS-11.2-RC1.
My ifconfig on FreeNAS is:
root@freenas:~ # ifconfig
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether d8:d3:85:b2:db:89
hwaddr d8:d3:85:b2:db:89
inet 192.168.11.50 netmask 0xffffff00 broadcast 192.168.11.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
ether 02:aa:62:f2:f6:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:9 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: vnet0:4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 2000
member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:7c:10:00:04:0a
hwaddr 02:7c:10:00:04:0a
status: active
groups: epair
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:7c:10:00:05:0a
hwaddr 02:7c:10:00:05:0a
status: active
groups: epair
vnet0:4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: transmission
options=8<VLAN_MTU>
ether 02:ff:60:03:aa:46
hwaddr 02:7c:10:00:06:0a
status: active
groups: epair
epair0b: flags=8842<BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:ff:60:03:aa:47
hwaddr 02:7c:10:00:07:0b
status: active
vnet0:9: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
hwaddr 02:7c:10:00:08:0a
status: active
groups: epair
On the transmission jail I only see this:
root@transmission:/ # ifconfig
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
My Transmission config.json is:
"CONFIG_VERSION": "14",
"allow_chflags": "0",
"allow_mlock": "0",
"allow_mount": "0",
"allow_mount_devfs": "0",
"allow_mount_nullfs": "0",
"allow_mount_procfs": "0",
"allow_mount_tmpfs": "0",
"allow_mount_zfs": "0",
"allow_quotas": "0",
"allow_raw_sockets": "0",
"allow_set_hostname": "1",
"allow_socket_af": "0",
"allow_sysvipc": "0",
"allow_tun": "0",
"available": "readonly",
"basejail": "yes",
"boot": "on",
"bpf": "no",
"children_max": "0",
"cloned_release": "11.2-RELEASE",
"comment": "none",
"compression": "lz4",
"compressratio": "readonly",
"coredumpsize": "off",
"count": "1",
"cpuset": "off",
"cputime": "off",
"datasize": "off",
"dedup": "off",
"defaultrouter": "",
"defaultrouter6": "none",
"depends": "none",
"devfs_ruleset": "4",
"dhcp": "off",
"enforce_statfs": "2",
"exec_clean": "1",
"exec_fib": "0",
"exec_jail_user": "root",
"exec_poststart": "/usr/bin/true",
"exec_poststop": "/usr/bin/true",
"exec_prestart": "/usr/bin/true",
"exec_prestop": "/usr/bin/true",
"exec_start": "/bin/sh /etc/rc",
"exec_stop": "/bin/sh /etc/rc.shutdown",
"exec_system_jail_user": "0",
"exec_system_user": "root",
"exec_timeout": "60",
"host_domainname": "none",
"host_hostname": "transmission",
"host_hostuuid": "transmission",
"host_time": "yes",
"hostid": "18DE8A80-1DD2-11B2-8000-D8D385B2DB89",
"hostid_strict_check": "off",
"interfaces": "bge0:bridge0",
"ip4": "new",
"ip4_addr": "vnet0|192.168.11.60/24",
"ip4_saddrsel": "1",
"ip6": "new",
"ip6_addr": "none",
"ip6_saddrsel": "1",
"jail_zfs": "off",
"jail_zfs_dataset": "iocage/jails/transmission/data",
"jail_zfs_mountpoint": "none",
"last_started": "2018-11-03 19:09:07",
"login_flags": "-f root",
"mac_prefix": "02ff60",
"maxproc": "off",
"memorylocked": "off",
"memoryuse": "off",
"mount_devfs": "1",
"mount_fdescfs": "1",
"mount_linprocfs": "0",
"mount_procfs": "0",
"mountpoint": "readonly",
"msgqqueued": "off",
"msgqsize": "off",
"nmsgq": "off",
"notes": "none",
"nsemop": "off",
"nshm": "off",
"nthr": "off",
"openfiles": "off",
"origin": "readonly",
"owner": "root",
"pcpu": "off",
"priority": "99",
"pseudoterminals": "off",
"quota": "none",
"release": "11.2-RELEASE-p4",
"reservation": "none",
"resolver": "/etc/resolv.conf",
"rlimits": "off",
"securelevel": "2",
"shmsize": "off",
"stacksize": "off",
"stop_timeout": "30",
"swapuse": "off",
"sync_state": "none",
"sync_target": "none",
"sync_tgt_zpool": "none",
"sysvmsg": "new",
"sysvsem": "new",
"sysvshm": "new",
"template": "no",
"type": "pluginv2",
"used": "readonly",
"vmemoryuse": "off",
"vnet": "on",
"vnet0_mac": "02ff6003aa46 02ff6003aa47",
"vnet1_mac": "none",
"vnet2_mac": "none",
"vnet3_mac": "none",
"vnet_default_interface": "none",
"vnet_interfaces": "none",
"wallclock": "off"
In a thread on resolving a tun0 issue for OpenVPN, a user suggested changing
to
"interfaces": "vnet0:bridge0",
but when I try that, the jail fails to start with:
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 541, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1628, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 503, in __start_jail__
_callback=self.callback)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError:
Stopped transmission due to VNET failure
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor
RuntimeError:
jgdempsey
I just tried enabling promiscuous mode on the host interface bge0 but that doesn't appear to have helped .. (checked after restarting the jail)
jgdempsey
Also, new vnet0:x interfaces seem to keep getting created for the transmission jail:
bge0: flags=28943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,PPROMISC> metric 0 mtu 1500
status: active
groups: lo
groups: bridge
member: vnet0:15 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000
member: vnet0:12 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
status: active
groups: epair
vnet0:4: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
ether 46:31:dd:43:c7:ee
status: active
vnet0:9: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
status: active
groups: epair
vnet0:12: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
hwaddr 02:7c:10:00:0a:0a
status: active
groups: epair
vnet0:15: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
hwaddr 02:7c:10:00:0c:0a
status: active
groups: epair
jgdempsey
Thanks, I deleted the jail and started from scratch using the new iocage code mentioned here: https://redmine.ixsystems.com/issues/40872
Networking on the jail is working, but I'm still working through the OpenVPN "Cannot allocate TUN/TAP dev dynamically" error.. The above should have solved it but unfortunately not for me
D
dlavigne
Guest
RC2 will have some additional fixes for the tun/tap issue.
