Jeff Lamer
- Nov 17, 2015
Hi All,
Apologizes for posting in two threads. We ran out of solutions in the other thread.
I updated to 11.2 and then tried to convert my warden jail to iocage and now have the following error.
Config.json
ifconfig
Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run return await self._call(f'{service_name}.{methodserviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 541, in start iocage.start() File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1628, in start callback=self.callback File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__ self.__start_jail__() File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 503, in __start_jail__ _callback=self.callback) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit _callback(content, exception) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback raise callback_exception(message) RuntimeError: Stopped sabnzbd_1 due to VNET failure """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call return await self._call_worker(serviceobj, name, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker job, File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) RuntimeError: Stopped sabnzbd_1 due to VNET failure
Config.json
"CONFIG_VERSION": "14", "allow_chflags": "0", "allow_mlock": "0", "allow_mount": "0", "allow_mount_devfs": "0", "allow_mount_nullfs": "0", "allow_mount_procfs": "0", "allow_mount_tmpfs": "0", "allow_mount_zfs": "0", "allow_quotas": "0", "allow_raw_sockets": "1", "allow_set_hostname": "1", "allow_socket_af": "0", "allow_sysvipc": "0", "allow_tun": "0", "available": "readonly", "basejail": "no", "boot": "on", "bpf": "no", "children_max": "0", "cloned_release": "EMPTY", "comment": "none", "compression": "lz4", "compressratio": "readonly", "coredumpsize": "off", "count": "1", "cpuset": "off", "cputime": "off", "datasize": "off", "dedup": "off", "defaultrouter": "none", "defaultrouter6": "none", "depends": "none", "devfs_ruleset": "4", "dhcp": "off", "enforce_statfs": "2", "exec_clean": "1", "exec_fib": "0", "exec_jail_user": "root", "exec_poststart": "/usr/bin/true", "exec_poststop": "/usr/bin/true", "exec_prestart": "/usr/bin/true", "exec_prestop": "/usr/bin/true", "exec_start": "/bin/sh /etc/rc", "exec_stop": "/bin/sh /etc/rc.shutdown", "exec_system_jail_user": "0", "exec_system_user": "root", "exec_timeout": "60", "host_domainname": "none", "host_hostname": "sabnzbd_1", "host_hostuuid": "sabnzbd_1", "host_time": "yes", "hostid": "00000000-0000-0000-0000-0CC47A693206", "hostid_strict_check": "off", "interfaces": "vnet0:bridge0", "ip4": "new", "ip4_addr": "vnet0|192.168.1.3/24", "ip4_saddrsel": "1", "ip6": "new", "ip6_addr": "none", "ip6_saddrsel": "1", "jail_zfs": "off", "jail_zfs_dataset": "iocage/jails/sabnzbd_1/data", "jail_zfs_mountpoint": "none", "last_started": "none", "login_flags": "-f root", "mac_prefix": "02ff60", "maxproc": "off", "memorylocked": "off", "memoryuse": "off", "mount_devfs": "1", "mount_fdescfs": "1", "mount_linprocfs": "0", "mount_procfs": "0", "mountpoint": "readonly", "msgqqueued": "off", "msgqsize": "off", "nmsgq": "off", "notes": "warden_id=2", "nsemop": "off", "nshm": "off", "nthr": "off", "openfiles": "off", "origin": "readonly", "owner": "root", "pcpu": "off", "priority": "99", "pseudoterminals": "off", "quota": "none", "release": "9.3-RELEASE", "reservation": "none", "resolver": "/etc/resolv.conf", "rlimits": "off", "securelevel": "2", "shmsize": "off", "stacksize": "off", "stop_timeout": "30", "swapuse": "off", "sync_state": "none", "sync_target": "none", "sync_tgt_zpool": "none", "sysvmsg": "new", "sysvsem": "new", "sysvshm": "new", "template": "no", "type": "jail", "used": "readonly", "vmemoryuse": "off", "vnet": "on", "vnet0_mac": "02837e000a0b 02837e000a0c", "vnet1_mac": "none", "vnet2_mac": "none", "vnet3_mac": "none", "vnet_default_interface": "none", "vnet_interfaces": "none", "wallclock": "off"
ifconfig
root@freenas:~ # ifconfig igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 0c:c4:7a:69:32:06 hwaddr 0c:c4:7a:69:32:06 inet 192.168.1.106 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 0c:c4:7a:69:32:07 hwaddr 0c:c4:7a:69:32:07 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:67:ee:c8:3f:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 8 priority 128 path cost 2000 member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 6 priority 128 path cost 2000 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 5 priority 128 path cost 2000 member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:0c:d0:00:05:0a hwaddr 02:0c:d0:00:05:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: sabnzbd_1 options=8<VLAN_MTU> ether 02:83:7e:00:0a:0b hwaddr 02:0c:d0:00:06:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair epair0b: flags=8842<BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:83:7e:00:0a:0c hwaddr 02:0c:d0:00:07:0b ether 02:83:7e:00:0a:0c hwaddr 02:0c:d0:00:07:0b nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: sabnzbd_1 options=8<VLAN_MTU> ether 02:83:7e:00:0a:0b hwaddr 02:0c:d0:00:08:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
