Alright how do I read this now? I know Reallocated_Event_Count, Current_Pending_Sector, and Offline_Uncorrectable all need to be 0 and they are. The temp is a bit high and I need to work out cable management better or change the case to get it down to 30. If there are no errors here but I got errors from badblocks does that mean there is a problem between the motherboard and the hard drives transferring data? I got errors on ada1-4 with a variety of description most seem to be about being unable to access the disk at that moment.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 87
3 Spin_Up_Time 0x0007 126 126 024 Pre-fail Always - 615 (Average 613)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 13
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 121 121 020 Pre-fail Offline - 34
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 237
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 13
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 13
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 13
194 Temperature_Celsius 0x0002 187 187 000 Old_age Always - 32 (Min/Max 23/37)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
[root@freenas] ~# smartctl -A /dev/ada1
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p12 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke,
www.smartmontools.org
2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 83
3 Spin_Up_Time 0x0007 123 123 024 Pre-fail Always - 627 (Average 627)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 22
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 22
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 35 (Min/Max 23/40)
[root@freenas] ~# smartctl -A /dev/ada2
2 Throughput_Performance 0x0005 137 137 054 Pre-fail Offline - 77
3 Spin_Up_Time 0x0007 125 125 024 Pre-fail Always - 619 (Average 617)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 15
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 23/38)
[root@freenas] ~# smartctl -A /dev/ada3
2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 82
3 Spin_Up_Time 0x0007 124 124 024 Pre-fail Always - 622 (Average 620)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 23
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 23
194 Temperature_Celsius 0x0002 176 176 000 Old_age Always - 34 (Min/Max 23/38)
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 1
[root@freenas] ~# smartctl -A /dev/ada4
2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 81
3 Spin_Up_Time 0x0007 126 126 024 Pre-fail Always - 612 (Average 609)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 24
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 24
194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 23/36)
[root@freenas] ~# smartctl -A /dev/ada5
2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 80
3 Spin_Up_Time 0x0007 125 125 024 Pre-fail Always - 617 (Average 618)
8 Seek_Time_Performance 0x0005 119 119 020 Pre-fail Offline - 35
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 236
194 Temperature_Celsius 0x0002 193 193 000 Old_age Always - 31 (Min/Max 23/35)
[root@freenas] ~# smartctl -A /dev/ada6
2 Throughput_Performance 0x0005 137 137 054 Pre-fail Offline - 79
3 Spin_Up_Time 0x0007 123 123 024 Pre-fail Always - 631 (Average 627)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 15
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 15
194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 23/37)
[root@freenas] ~# smartctl -A /dev/ada7
3 Spin_Up_Time 0x0007 127 127 024 Pre-fail Always - 607 (Average 605)
194 Temperature_Celsius 0x0002 200 200 000 Old_age Always - 30 (Min/Max 23/33)
[root@freenas] ~# smartctl -A /dev/ada8
2 Throughput_Performance 0x0005 135 135 054 Pre-fail Offline - 84
3 Spin_Up_Time 0x0007 126 126 024 Pre-fail Always - 615 (Average 612)
194 Temperature_Celsius 0x0002 187 187 000 Old_age Always - 32 (Min/Max 23/36)
