MakeMKV mount usb optical drive
ncw1978
Hi I am trying to use makemkv to rip my bluerays onto my server and I am having trouble getting it to recognise my usb optical drive. Is there a mount option I have to put in the container .
I am pretty new to this server stuff so my linux knowledge is a bit laking.
Thanks
ncw1978
I have solved adding one drive to it in the resource section but I am struggling to get another device usb blu ray drive to show up to rip 2 off at the same time. Does anyone have any info on this.
Thanks
ncw1978
Both drives are usb and where working great but I have since made a mistake and deleted handbrake. Trying to get it working again
Arwen
Another person is doing something similar in the below thread. He is using MakeMKV and had it working. Then a power cycle to move things around, and now it no longer works.
Sawtaytoes
That's the issue I had. I eventually moved all those drives to my Windows PC instead. It was too hit-or-miss on TrueNAS.
ncw1978
I have it working for makemkv now added /dev/sr0 to usb config on the makemkv usb section on install and it works great
Martin Jones
I just followed the above guide and It works! I'm Astounded, over the moon and truly grateful. I have been working with FreeNAs for years and now I'm getting used to scale and Truecharts. I'm loving it. I hope I'm not tempting fate!!!!!!!!!
Martin Jones
Unfortunately no, I just added exactly what was in this guide
I'm not new, but fairly dumb when it comes to Linux so I was groping in the dark too. There is a piece at the bottom of the page that has an additional entry if it wasn't already set this way. It works so far
