I have installed FreeNAS into a ESXi VM. When it initially comes up and grabs a DHCP address it works just fine. The problem happens when I try to give it a static address.
I have done this through the console and from the web interface.
In the console I chose option 1.
Interface 1
delete existing: n
configure for DHCP: n
Configure IPv4: y
Interface name: LAN
IPv4 Address: 10.2.61.13/16
saving interface config: ok
config IPv6: n
Then the screen refreshes and says that i can go to http://10.2.61.13
when I do it times out.
I can ping 10.2.61.13 though.
What exactly am I doing wrong?
Interface 1
delete existing: n
Configure IPv4: y
Interface name: LAN
config IPv6: n
