I have searched both Google and forums and have seen some similar issues, but the only one that came close to mine involved VLANs and I am not using any VLANs.
This issue occurs during two separate scenarios.
1) Immediately after configuring network for the first time
2) Immediately after rebooting system
After configuring the network interfaces (option #1) In the console menu I see the static IP address I have assigned. However, both ICMP and TCP traffic fail to generate replies to my desktop (Windows) when trying to connect (SSH/web GUI, as well as ping). ICMP traffic indicates "Destination host unreachable". FreeNAS console system messages indicate that the NTP lookups are failing as well, telling me that routed traffic outbound from FreeNAS system is also not working, not just inbound traffic from LAN.
Steps taken to reproduce:
1) Reset to factory defaults
2) Configure network interface
2a) Reset interface config? Y
2b) Configure DHCP? N
2c) IPv4: 172.24.24.32/23
2d) IPv6: N
3) New IP shows in console menu. Test WebGUI / ping from desktop (source 172.24.24.64/23): Fail
4) In FreeNAS console, enter shell and restart interface (ifconfig re0 down, ifconfig re0 up)
5) New IP still shows in console menu. Test WebGUI / ping from desktop (172.24.24.64/23): Success
6) Reboot
7) New IP still shows in console menu. Test WebGUI / ping from desktop (172.24.24.64/23): Fail
8) Repeat restart of interface from shell
9) New IP still shows in console menu. Test WebGUI / ping from desktop (172.24.24.64/23): Success
FreeNAS Version: FreeNAS-9.3-STABLE-201505130355
Hardware
Motherboard / CPU: AsRock QC5000-ITX/Wifi AMD FT3 Kabini A4-5000 Quad-Core APU (Embedded combo)
RAM: 16 GB (2 x 8GB G.SKILL Sniper Gaming Series DDR3 1600) Non-ECC
NIC: Onboard Realtek RTL8111E (10/100/1000 Mbps)
Boot Drive: Patriot USB Flash Drive (8 GB, USB 2.0)
HDDs: Currently 3 (eventually 4) Seagate 3TB - ST3000DM001 (not yet added to FreeNAS)
2d) IPv6: N
6) Reboot
Hardware
