I hope somebody will be able to help me figure out this puzzle, please;
The Set-up
I have 2x machines, each running TrueNas Core 12.0-U8.1. They are not exactly the same spec;
Each of the above uplinks to a Cisco Nexus 3064 switch also with MTU set to 9000. In turn the Cisco is also linked to 2x HP DL360p servers each equipped with 10GbaseSR cards, and running VSphere 6.7
iSCSi is enabled on both Server A and B, bound to the fibre interfaces on respective VLANs
2x zvols of 6TB and 3TB respectively are created on the singular volume for each server, logical blocksize 512k, and then presented on LUNs to VSphere, where it has created VMFS6 datastores for each.
Multipath IO is set up round-robin IOP=1
The problem
Traffic from A to B and vice-versa, as would be generated by VMotion seems to flow OK and as expected. Performance I feel could be better, but that will involve some more configuration within VSphere.
What I do notice though is when transferring large amounts of data between A and B or from B to A;
Server A CPU usage remains virtually on the floor - maybe 10% max whilst both 10GbaseSR interfaces are showing Outs of appox 50MiB/s each
Server B CPU usage is bobbing up and down ranging from 30% to 100%, the 10GbaseSR interfaces are showing Ins that are similar to Server A Outs i.e. 50Mib/s
The situation can be reversed, by getting traffic to flow from B to A at similar rates. Similar differences in the CPU levels are seen i.e. Server A = Low, Server B = High
I've been racking my brains to try figure out why there would be such a difference in the CPU load. I see no obvious configuration differences across the 2 servers, other than the difference in hardware specs per above.
It might not even be a problem as such, just a "feature", but could anybody please offer me a clue as to why Server B CPU is high? Thanks in advance
Andy (P.S. Please let me know if you need me to provide any other config information)
The Set-up
Server A AMD Ryzen 5 3600 6-cores 32GB unbuffered Memory (non-ECC) 8 x 6TB SAS 12Gb split into 2x RAIDZ1 vdevs 4x drives each 1x NVMe Log drive 2 x 10GbaseSR LC-LC Fibre interfaces MTU 9000 Hardware Offloading Enabled | Server B AMD Ryzen 7 2700x 8-cores 64GB unbuffered ECC Memory 8 x 10TB SAS 12Gb split into 2x RAIDZ1 vdevs 4x drives each 1x NVMe Log drive 1x NVMe Cache drive 2 x 10GbaseSR LC-LC Fibre interfaces MTU 9000 Hardware Offloading Enabled |
The problem
