MAC slow transfer speed AFP, CIFS
Hi
i built freenas server from
Motherboard: ASRock Q1900DC-ITX - Intel J1900
RAM: 2x Kingston Value 4GB DDR3 1600 CL11 1.35V SODIMM
HDD: 2x3TB WD RED ( ZFS mirror)
USB FLASH: 1x16Gb for system and 1x32GB for System Dataset(USB 2.0)
I installed fresh instalation of Freenas 9.3 and when i was trying to copy files from PC to nas the maximum write speed was 6mbps, I tested it with BlackMagic.
I have the same speed with AFP and CIFS. I tryied autotune but it doesnt help.
When i was trying this nas wit windows 7, everything was ok, its not working only with mac Yosemite 10.10.
What should I change?
Thanks for help
SweetAndLow
Sweet'NASty
Are you using Wi-Fi or Ethernet? Are you using with the same files as windows? What is the source of the data it could just be your Mac is slower. Remove everything auto tune changed that will probably not help.
im using Edimax EU-4306 gigabit usb3 ethernet adapter in macbook pro late 2013
i have gigabit switch between pc and nas
but i also tryed AC wifi and i had the same result
im trying to copy 4gb movie file
here is my speed
wDlPreJs9olgy5cgkAboTcSR7pEJBu-3NcM3iO9grjLmc4wzI_U-7BsEY1pKxJd-4oTdfAWUkHETMYI=w1656-h852
