For three months I've been dealing with an issue with my LSI 2308 onboard HBA. It sometimes records MILLIONS of checksum errors, sometimes has a CAM error and locks up the server install, and often takes the disks on my LSI controller offline.
I've highlighted this in multiple threads, which I'll reference, in case you're really bored. To summarize:
I've replaced SATA cables
I've tested the drives / pool on the primary controller and it generally worked - though CAM still locked up randomly
I sent the motherboard to Supermicro who tested and said the controller is fine.
I've updated to IT firmware 20.00.07.00
My first thread:
https://forums.freenas.org/index.php?threads/volume-disappeared-after-improper-shutdown.61567/
Questioning the disks:
https://forums.freenas.org/index.php?threads/failing-disk-or-sata-cable.61725/#post-441746
Follow-up:
https://forums.freenas.org/index.php?threads/new-user-woes.62019/
I re-assembled the entire machine and started it up today. The drives failed to populate at all. Because of the issues, the left side of my GUI won't generate, and just spins bars. I'm at a serious loss. This is my log output, littered with CAM status errors and SCSI status errors...
My first thread:
Follow-up:
Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): CAM status: SCSI Status Error Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): SCSI status: Check Condition Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): Retrying command (per sense data) Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 08 00 00 20 00 length 16384 SMID 904 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 08 00 00 20 00 Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:52 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 08 00 00 20 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: SCSI Status Error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): SCSI status: Check Condition Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command (per sense data) Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 08 00 00 20 00 length 16384 SMID 916 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 08 00 00 20 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Error 5, Retries exhausted Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 30 00 00 08 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: SCSI Status Error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): SCSI status: Check Condition Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command (per sense data) Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 length 16384 SMID 912 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 length 8192 SMID 901 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 length 8192 SMID 911 terminated ioc 804b log(da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 Apr 20 14:06:53 FreeNAS info 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 length 8192 SMID 900 terminated ioc 804b loginfo 31120303 scsi(da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 Apr 20 14:06:53 FreeNAS 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: SCSI Status Error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): SCSI status: Check Condition Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command (per sense data) Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 length 16384 SMID 906 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 length 8192 SMID 895 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 length 8192 SMID 874 terminated ioc 804b log(da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 Apr 20 14:06:53 FreeNAS info 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 length 8192 SMID 878 terminated ioc 804b log(da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS info 31120303 scsi 0 state c xfer 0 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:53 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: SCSI Status Error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): SCSI status: Check Condition Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Retrying command (per sense data) Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 length 16384 SMID 919 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 length 8192 SMID 917 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 length 8192 SMID 920 terminated ioc 804b loginfo 31120303 scsi(da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 Apr 20 14:06:54 FreeNAS 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 length 8192 SMID 899 terminated ioc 804b log(da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 Apr 20 14:06:54 FreeNAS info 31120303 scsi 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Error 5, Retries exhausted Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: SCSI Status Error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): SCSI status: Check Condition Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Retrying command (per sense data) Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 length 8192 SMID 909 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 length 8192 SMID 907 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 length 16384 SMID 923 terminated ioc 804b loginfo 31120303 sc(da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00 Apr 20 14:06:54 FreeNAS si 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Error 5, Retries exhausted Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Retrying command Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: SCSI Status Error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): SCSI status: Check Condition Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Error 6, Retries exhausted Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Invalidating pack Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 length 16384 SMID 914 terminated ioc 804b loginfo 31120303 scsi 0 state c xfer 0 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): WRITE(10). CDB: 2a 00 06 a6 b9 38 00 00 20 00 Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): CAM status: CCB request completed with an error Apr 20 14:06:54 FreeNAS (da2:mps0:0:2:0): Error 5, Retries exhausted Apr 20 14:07:00 FreeNAS ZFS: vdev state changed, pool_guid=1987451638458025078 vdev_guid=11380074299853842333 Apr 20 14:07:01 FreeNAS mps0: mpssas_prepare_remove: Sending reset for target ID 4 Apr 20 14:07:01 FreeNAS da4 at mps0 bus 0 scbus0 target 4 lun 0 Apr 20 14:07:01 FreeNAS da4: <ATA ST8000VN0022-2EL SC61> s/n ZA19RMDB detached Apr 20 14:07:01 FreeNAS GEOM_MIRROR: Device swap1: provider da4p1 disconnected. Apr 20 14:07:01 FreeNAS (da4:mps0:0:4:0): Periph destroyed Apr 20 14:07:02 FreeNAS (pass0:mps0:0:0:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 921 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0 Apr 20 14:07:02 FreeNAS mps0: Unfreezing devq for target ID 4 Apr 20 14:07:03 FreeNAS ZFS: vdev state changed, pool_guid=1987451638458025078 vdev_guid=2760554092486413937 Apr 20 14:07:04 FreeNAS mps0: mpssas_prepare_remove: Sending reset for target ID 1 Apr 20 14:07:04 FreeNAS da1 at mps0 bus 0 scbus0 target 1 lun 0 Apr 20 14:07:04 FreeNAS da1: <ATA ST8000VN0022-2EL SC61> s/n ZA19RMP0 detached Apr 20 14:07:04 FreeNAS GEOM_MIRROR: Device swap2: provider da1p1 disconnected. Apr 20 14:07:04 FreeNAS (da1:mps0:0:1:0): Periph destroyed Apr 20 14:07:04 FreeNAS (pass0:mps0:0:0:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 926 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0 Apr 20 14:07:04 FreeNAS (pass0:mps0:0:0:0): INQUIRY. CDB: 12 00 00 00 40 00 length 64 SMID 918 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0 Apr 20 14:07:06 FreeNAS (pass2:mps0:0:2:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 928 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0 Apr 20 14:07:06 FreeNAS mps0: Unfreezing devq for target ID 1 Apr 20 14:07:08 FreeNAS (pass0:mps0:0:0:0): INQUIRY. CDB: 12 00 00 00 40 00 length 64 SMID 908 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0 Apr 20 14:07:09 FreeNAS ZFS: vdev state changed, pool_guid=1987451638458025078 vdev_guid=12391365849909013340 Apr 20 14:07:09 FreeNAS mps0: mpssas_prepare_remove: Sending reset for target ID 0 Apr 20 14:07:09 FreeNAS da0 at mps0 bus 0 scbus0 target 0 lun 0 Apr 20 14:07:09 FreeNAS da0: <ATA ST8000VN0022-2EL SC61> s/n ZA19R9BM detached Apr 20 14:07:09 FreeNAS (da0:mps0:0:0:0): Periph destroyed Apr 20 14:07:09 FreeNAS mps0: Unfreezing devq for target ID 0 Apr 20 14:07:11 FreeNAS (pass2:mps0:0:2:0): INQUIRY. CDB: 12 00 00 00 40 00 length 64 SMID 925 terminated ioc 804b loginfo 31170000 scsi 0 state c xfer 0 Apr 20 14:07:11 FreeNAS (pass2:mps0:0:2:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 929 terminated ioc 804b loginfo 31170000 scsi 0 state c xfer 0 Apr 20 14:07:11 FreeNAS (pass2:mps0:0:2:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 915 terminated ioc 804b loginfo 31170000 scsi 0 state c xfer 0 Apr 20 14:07:13 FreeNAS (pass3:mps0:0:3:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 937 terminated ioc 804b loginfo 31170000 scsi 0 state 0 xfer 0 Apr 20 14:07:13 FreeNAS (pass2:mps0:0:2:0): INQUIRY. CDB: 12 00 00 00 40 00 length 64 SMID 930 terminated ioc 804b loginfo 31170000 scsi 0 state 0 xfer 0 Apr 20 14:07:13 FreeNAS (pass2:mps0:0:2:0): INQUIRY. CDB: 12 00 00 00 40 00 length 64 SMID 931 terminated ioc 804b loginfo 31170000 scsi 0 state 0 xfer 0 Apr 20 14:07:13 FreeNAS ZFS: vdev state changed, pool_guid=1987451638458025078 vdev_guid=5839067863432692929 Apr 20 14:07:13 FreeNAS mps0: mpssas_prepare_remove: Sending reset for target ID 3 Apr 20 14:07:13 FreeNAS mps0: mpssas_prepare_remove: Sending reset for target ID 2 Apr 20 14:07:13 FreeNAS da3 at mps0 bus 0 scbus0 target 3 lun 0 Apr 20 14:07:13 FreeNAS da3: <ATA ST8000VN0022-2EL SC61> s/n ZA19MY4K detached Apr 20 14:07:13 FreeNAS da2 at mps0 bus 0 scbus0 target 2 lun 0 Apr 20 14:07:13 FreeNAS da2: <ATA ST8000VN0022-2EL SC61> s/n ZA19RMRK detached Apr 20 14:07:13 FreeNAS GEOM_MIRROR: Device swap2: provider da2p1 disconnected. Apr 20 14:07:13 FreeNAS GEOM_MIRROR: Device swap1: provider da3p1 disconnected. Apr 20 14:07:13 FreeNAS GEOM_MIRROR: Device swap2: provider destroyed. Apr 20 14:07:13 FreeNAS GEOM_MIRROR: Device swap2 destroyed. Apr 20 14:07:13 FreeNAS GEOM_ELI: Device mirror/swap2.eli destroyed. Apr 20 14:07:13 FreeNAS GEOM_ELI: Detached mirror/swap2.eli on last close. Apr 20 14:07:13 FreeNAS GEOM_MIRROR: Device swap1: provider destroyed. Apr 20 14:07:13 FreeNAS GEOM_MIRROR: Device swap1 destroyed. Apr 20 14:07:13 FreeNAS GEOM_ELI: Device mirror/swap1.eli destroyed. Apr 20 14:07:13 FreeNAS GEOM_ELI: Detached mirror/swap1.eli on last close. Apr 20 14:07:13 FreeNAS mps0: Unfreezing devq for target ID 3 Apr 20 14:07:13 FreeNAS mps0: Unfreezing devq for target ID 2 Apr 20 14:07:13 FreeNAS (da3:mps0:0:3:0): Periph destroyed Apr 20 14:07:13 FreeNAS (da2:mps0:0:2:0): Periph destroyed Apr 20 14:07:13 FreeNAS ZFS: vdev state changed, pool_guid=1987451638458025078 vdev_guid=13734883185564571814 Apr 20 14:07:17 FreeNAS mps0: IOC Fault 0x40002651, Resetting Apr 20 14:07:17 FreeNAS mps0: Reinitializing controller, Apr 20 14:07:17 FreeNAS mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd Apr 20 14:07:17 FreeNAS mps0: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc> Apr 20 14:07:17 FreeNAS mps0: mps_reinit finished sc 0xfffffe000157d000 post 2 free 1 Apr 20 14:07:27 FreeNAS mps0: IOC Fault 0x40002651, Resetting Apr 20 14:07:27 FreeNAS mps0: Reinitializing controller, Apr 20 14:07:27 FreeNAS mps0: Portenable NULL reply Apr 20 14:07:27 FreeNAS mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd Apr 20 14:07:27 FreeNAS mps0: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc> Apr 20 14:07:27 FreeNAS mps0: mps_reinit finished sc 0xfffffe000157d000 post 2 free 1 Apr 20 14:07:31 FreeNAS mps0: IOC Fault 0x40005871, Resetting Apr 20 14:07:31 FreeNAS mps0: Reinitializing controller, Apr 20 14:07:31 FreeNAS mps0: Portenable NULL reply Apr 20 14:07:31 FreeNAS mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd Apr 20 14:07:31 FreeNAS mps0: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc> Apr 20 14:07:31 FreeNAS mps0: mps_reinit finished sc 0xfffffe000157d000 post 2 free 1
