Lost all pools
Jaroslav Jasek
Helo,
HOw can I restore all lose pools ?
I can start TrueNAS without any problem, but I dont see any pool.
Many thanks for any help very important.
we had ransomware attack and lot of files are encrypted.
I don't know what a coincidence it is - but in the same time (when we need restore our files) we loss all pools on our TrueNAS.
I see all disk in the Storage, but not any pool.
Regards
Jaroslav Jasek
SweetAndLow
Sweet'NASty
zpool import cmd will show you what pools are available to import. Start with that and show us the output.
You can also just try and import them via the gui but I suspect something else is going on and that's not going to work.
Jaroslav Jasek
I try restore my saved configuration, when I was updated from FreeNAS to TrueNAS in 2/2021.
The screen is in the attachment.
This show all pools, but are encrypted.
zpool import output :
root@freenas[~]# zpool import
no pools available to import
root@freenas[~]#
Were those pools encrypted before?
Jaroslav Jasek
Yes - Were those pools encrypted before
HolyK
Ninja Turtle
Jaroslav Jasek
Yes - I have the encryption keys
HolyK
Ninja Turtle
Try to manually decrypt each disk and then import from CLI:
geli attach -r -k /data/geli/correct_key_name.key /dev/(a)daXp2
// Replace the keyfile name and devices. It asks for a passphrase - enter it.
// Repeat for each encrypted disk from the same pool. Pay attention to the "p2" at the end.
zpool import zpool import <poolname>
If you have multiple disks and you don't know which one belongs to which pool you can try ti dig in your CFG backup. Or from GELI cache file. There are multiple ways but we would need more details about your system
Provide output of these:
zpool status gpart show glabel status
Also query config DB
sqlite3 /data/freenas-v1.db SELECT storage_volume.vol_name, storage_encrypteddisk.encrypted_provider from storage_volume JOIN storage_encrypteddisk ON storage_volume.id = storage_encrypteddisk.encrypted_volume_id;
Jaroslav Jasek
root@freenas[~]# zpool status
pool: freenas-boot
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
the features. See zpool-features(5) for details.
scan: scrub repaired 0B in 00:03:01 with 0 errors on Thu Apr 15 03:48:02 2021
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da4p2 ONLINE 0 0 0
errors: No known data errors
root@freenas[~]# glabel status
Name Status Components
gptid/f7214ba9-a0e9-11ea-85d6-2c59e5392d50 N/A da0p2
gptid/09ca2eea-4a42-11e9-87ef-2c59e5392d50 N/A da1p2
gptid/0db55957-4a42-11e9-87ef-2c59e5392d50 N/A da2p2
gptid/119a115c-4a42-11e9-87ef-2c59e5392d50 N/A da3p2
gptid/210af1de-4680-11e9-9b40-2c59e5392d50 N/A da4p1
gptid/fb9cb9df-467c-11e9-961c-2c59e5392d50 N/A da5p2
gptid/0261884d-467d-11e9-961c-2c59e5392d50 N/A da6p2
gptid/d3ceafdf-5799-11e9-9890-2c59e5392d50 N/A da7p2
gptid/637778ee-91c6-11e9-adf9-2c59e5392d50 N/A da8p2
gptid/c098a878-5883-11e9-9890-2c59e5392d50 N/A da9p2
gptid/e194f7a2-a0f6-11ea-85d6-2c59e5392d50 N/A da10p2
gptid/e14c4837-a0f6-11ea-85d6-2c59e5392d50 N/A da10p1
gptid/c05aaa71-5883-11e9-9890-2c59e5392d50 N/A da9p1
gptid/631da399-91c6-11e9-adf9-2c59e5392d50 N/A da8p1
gptid/d3929e3e-5799-11e9-9890-2c59e5392d50 N/A da7p1
gptid/02444cbc-467d-11e9-961c-2c59e5392d50 N/A da6p1
gptid/fb829bea-467c-11e9-961c-2c59e5392d50 N/A da5p1
gptid/11798309-4a42-11e9-87ef-2c59e5392d50 N/A da3p1
gptid/0d92f0a6-4a42-11e9-87ef-2c59e5392d50 N/A da2p1
gptid/09aaf4bc-4a42-11e9-87ef-2c59e5392d50 N/A da1p1
gptid/f6f645e9-a0e9-11ea-85d6-2c59e5392d50 N/A da0p1
root@freenas[~]#
root@freenas[~]# gpart show
=> 40 3907029088 da0 GPT (1.8T)
40 88 - free - (44K)
128 4194304 1 freebsd-swap (2.0G)
4194432 3902834696 2 freebsd-zfs (1.8T)
=> 40 3907029088 da1 GPT (1.8T)
=> 40 3907029088 da2 GPT (1.8T)
=> 40 3907029088 da3 GPT (1.8T)
=> 40 861357376 da4 GPT (411G)
40 1024 1 freebsd-boot (512K)
1064 861339648 2 freebsd-zfs (411G)
861340712 16704 - free - (8.2M)
=> 40 7814037088 da5 GPT (3.6T)
4194432 7809842696 2 freebsd-zfs (3.6T)
=> 40 7814037088 da6 GPT (3.6T)
=> 40 7814037088 da7 GPT (3.6T)
=> 40 7814037088 da8 GPT (3.6T)
=> 40 7814037088 da9 GPT (3.6T)
=> 40 7814037088 da10 GPT (3.6T)
