Locking local path '/mnt/tank' for reading
robinmorgan
Hello all!
Running a Cloud Sync Task for S3 seems to go nowhere. I have tried created new datasets with clean permissions.
Any suggesting?
Samuel Tai
How deeply are these datasets nested? I don't experience these locks during S3 sync with a dataset at the root level. Remember, you'll need to look at the permissions not just at the level you want to replicate, but in all parent datasets as well.
robinmorgan
Great question, thank you, they are 3 layers deep. I have created new test set and I have the same issue.
'/mnt/tank1/test2'
Samuel Tai
How do you have your cloud sync defined? Are you using the new v2 AWS signatures in your cloud credentials?
Samuel Tai
Under System->Cloud Credentials, did you define things like this?
Did you verify your credential by clicking the button?
Samuel Tai
OK, then how do you have the cloud sync task defined?
robinmorgan
Interesting. The job ran today, the only difference is my B2 Task had finished. Can you run two tasks at once?
Samuel Tai
In principle, it should be possible to run more than 2 cloud syncs at once, but looking at /usr/local/lib/python3.7/site-packages/middlewared/plugins/cloud_sync.py, which implements the job, I see some implementation details that may prevent more than one sync from running:
  • Line 136 starts logic that generates a temporary config file for the rclone job. I don't know if rclone can deal with multiple configs in memory.
  • Line 1001 generates the "Locking local path" message during the job, and if another job is running in the same path, the other job's lock will prevent this job from gaining the lock until the other job completes.
robinmorgan
Great work, thank you for your help. The B2 push and the AWS Push were on the separate datasets. I'm moving everything to AWS deep so this shouldn't be an issue in the future! Thank you again!
Samuel Tai
You're welcome. It's also possible that you may not have verified the credential at the beginning, and the sync started working once the credential was verified.
