Philip Robar
- Jun 10, 2014
Hello, I'm an ex-Sun Microsystems jack-of-all-trades software engineer currently self-banished to Central Michigan, who has been using FreeNAS/ZFS on and off for many years—going back well before its iXsystems days. I had switched to EON (and for a little while Linux based ClarkConnect/ClearOS), as it is Solaris based, but since it seems to have stagnated I switched back to FreeNAS. I've stayed with FreeNAS as opposed to an illumos based solution like Nexenta mostly because of FreeNAS's plugins and good documentation.
My current server:
FreeNAS 9.10.1 Stable
Lenovo ThinkServer TS140
Intel C226 chipset
Intel Core i3-4330 (Specified as a 4130, but who I am I to complain about a free upgrade?)
16GB ECC RAM (4x4GB, 32GB max)
Built-in audio & video, USB3 (Seems stable and really makes backups go quickly.)
LSI SAS3041E-R 4x SATA/SAS PCIe HD Controller (Flashed to IT mode, 2TB limited.)
3TB: 2x3TB mirror (WD Green with fixed idle, Seagate ST3000DM001 [Fingers crossed. ;-)])
2TB: 2x2TB mirror
500GB: 2x500GB mirror
Usage: SMB file sharing, Time Machine Backups, Jail: Plex Media Server & SiliconDust DVR
The barebones Lenovo TS140 with either the Core i3 (low price $220) or Xeon (low $300's) is currently (mid-2015) the best value available for most SOHO or Home Server DIY users as long as you're happy with a small tower case. It's nearly silent. It uses an Intel server chipset, supports 5 drives and ECC memory and it's cheap — you literally can't build it yourself for less. Don't go with a SuperMicro, etc. solution unless you're absolutely sure that you need to. Yes, I really wanted to build a from-scratch-system using a cool U-NAS case and a mini-ITX/Avoton motherboard, but I just couldn't justify the extra cost. An Avoton motherboard alone, with no memory, costs more than the TS140.
The TS140 could also be the basis of a very nice desktop machine as it has audio and 2 Display Ports (and VGA) for video.
Notes:
Supermicro X7DCA-L in a 1U case (purchased used for a great price)
2xIntel Xeon L5420 (Low power, 2.5 GHz, 2x4=8 cores)
1x8GB DDR2 ECC RAM (Max 6x8=48)
Geekbench 3 Single-core: 1414
Geekbench 3 Multi-core: 9314 (Good enough to transcode 1080P in Plex)
It's currently being used to rename, remux and transcode all of my WTV/MPEG2 TV recordings to MKV/h.264 via MCEBuddy and Handbrake 0.10.x. Handbrake scales linearly to all 8 cores giving me roughly the same performance as my Core i5-2500s iMac (4 cores).
Phil
My current server:
Intel C226 chipset
2TB: 2x2TB mirror
Notes:
- Lenovo's drive cages are grossly overpriced and ruin the value proposition of the TS140. I wouldn't bother with them as you can easily hack three drives into the upper drive cage.
- If you really need easy access to, or hot plugging of, the storage drives the case could be hacked to fit an X in Y drive cage.
- To use the out of band remote admin features you have to use a Xeon CPU.
Phil
