I was running happily on 8.2.0 x86 with no issues until my system drive (IDE) died. I had an Dual Core CPU with 8 Gigs laying around from a ESXI Whitebox that had been upgraded to 6 cores with 16GB. I installed 8.3.1 noticed that I could not change Admin Password in fact I could not make any changes at all. The left pane would not populate. So I downloaded 8.2.0 x64 and reinstalled with no issues. Once this was all working I downloaded 8.3.0 x64 and performed an upgrade everything looked good except the left pane did not populate, totally blank. However the right pane was normal. I did the zpool upgrade with no issues. I then did the 8.3.1 x64 upgrade and still have the same issue the left pane is blank and I also notice (r12686+b770da6_dirty).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
