khartahk
- Feb 13, 2015
I'm trying to set up FreeIPA auth for FreeNAS. I've managed to set it up so that i can ssh into the FreeNAS using FreeIPA credentials and also using the ssh key in FreeIPA - but this last part only if I manualy fix the /usr/local/etc/sssd/sssd.conf file. I have to do the following:
services = ssh,nss,pam,sudo # here I add "ssh" -> this I can do via Auxiliary Parameters:
domains = domain.tld # change IPA to domain.tld
[ssh] #add this also just in case -> this I can do via Auxiliary Parameters:
[domain/IPA] #have to change "IPA" to "domain.tld", but after every save in GUI this changes back
Why is the GUI setting domain name to IPA? How or where do I need to make a change so that this stops or uses the correct domain.tld?
For now I've set up a post-init copy of the correct sssd.conf file and service sssd restart.
