Hello guys,
I did an upgrade of my NAS to new hardware and faced an error during migration -> Apps can't be installed + VMs run unstably, I'm getting "Kubernetes service is not running"
What happened before issue (prerequisites):
- Hardware upgrade from old Intel v3 to new Ryzen 5800x:
MB: Supermicro X10SLL-F ---> Asrock Rack X570D4U
CPU: Xeon E3 1271 v3 ---> Ryzen 5800X
RAM: 32 Gb ECC ---> 64Gb nonECC
Added 1Tb NVMVe
- Upgrade from RC1.2 to RC2 at the same time
Unfortunately, the OS upgrade happened exactly during the hardware upgrade, so I still don't know what is the root cause of my problem...
Problem description:
I can't install any apps because I get a "Kubernetes service is not running" error.
Also, VMs runs very unstably: VM runs ok after initial configuration, but it stuck somewhere after reboot - no VNC at all, doesn't work properly. I think it can be connected to App issue.
What I tried to solve a problem:
- Import old config to the new installed TrueNAS;
- Move application pool assignment to another existing pool;
- Completely destroy the app pool and create a new one from scratch;
- Do everything from scratch (freshly new installed TrueNAS).
I noticed a few similar treads, but "reboot + destroy and recreate app pool" don't work in my case.
Maybe someone has any idea or solution? If anyone had similar issues with AMD builds, it will be helpful as well.
P.S. I have properly configured "Route v4 Interface" and "Route v4 Gateway" in apps settings.
Thank you in advance!
Added 1Tb NVMVe
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 409, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 445, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1137, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1269, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 478, in do_create
await self.middleware.call('kubernetes.validate_k8s_setup')
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1324, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1281, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 322, in validate_k8s_setup
raise CallError('Kubernetes service is not running.')
middlewared.service_exception.CallError: [EFAULT] Kubernetes service is not running.
[EFAULT] Kubernetes service is not running.Also, VMs runs very unstably: VM runs ok after initial configuration, but it stuck somewhere after reboot - no VNC at all, doesn't work properly. I think it can be connected to App issue.
