lonemuffin
- Feb 1, 2022
I recently updated my TrueNAS Scale system to version 22.02.1 and now my apps don't seem to be running and are not installable. Every time I try to install and start apps like netdata or plex, it says:
Error
[EFAULT] Kubernetes service not running.
Then lists the following info:
I'm not sure if it matters or not but a couple months ago I unmounted then mounted my pool to rename it, which was successful, however I don't think I noticed any problems with the apps. Not sure if that could be the cause as well or not. Any help would be greatly appreciated.
Error
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 412, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 448, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1129, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 378, in do_create await self.middleware.call('kubernetes.validate_k8s_setup') File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1308, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1257, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 335, in validate_k8s_setup raise CallError(error) middlewared.service_exception.CallError: [EFAULT] Kubernetes service is not running.
