kernel panic during boot
axelmahone
My friends freenas does not boot anymore.
We updated his system from 9.x to 11.2 a couple of weeks ago.
A short review over the process:
  • we installed a fresh version of Freenas 11.2 on a usb drive
  • we restored his ZFS pool (RAIDZ1)
  • we devided his data volume into sub datasets and moved the data
  • set up users and shares
  • he bought a new ssd and we copied the boot device to the new drive (with dd)
  • created a jail (on the data-volume)
It was running fine for a couple of weeks, but now he gets an assert (zap_increment_int [0x7a == 0x0]) resulting in a kernel panic while booting the system.
According to this resource it is a checksum error: https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=220203
This case was in connection with a SAS controller, which we do not have.
Does anyone have an advice how to fix this issue?
It is for private use and I always have the option to reinstall the complete system within a couple of hours, but out of curiosity I want to try to find and fix the cause.
Hardware:
ASRock 75 Pro+ (latest UEFI)
AMD A4-3400
16 GB RAM
250 GB SSD boot device
4*3 TB WD Red
(no need to point out it's consumer hardware, I am totally aware of that :) )
What brand/model is the boot SSD? if this is one of the drives impacted by the 3D NAND/TRIM issue, you may need to replace it.
Typically this would be WD Green or some Crucial drives, but can be others too.
Also be aware that disabling TRIM is system-wide, so all SSDs will be impacted by that.
The better way forward is with a $30 Kingston SSD (doesn't need to be very big). Use the SanDisk in a Windows or Linux machine for now until FreeNAS squashes that bug.
Chris Moore
Intel SSD drives have worked well for me. You can pickup a very good used model for little money:
Something like this would probably outlast two servers:
I have some that I have been using for four years with zero trouble.
axelmahone
Yesterday I did a scrub on the boot pool. Now I can confirm there were checksum errors.
He bought a new USB flash drive today and I will install a fresh copy of FreeNAS.
Is it a bug in FreeNAS or with ZFS in general? I am using some NVMe SSDs with ZFS in my rigs.
anmnz
The bug appears to manifest with specific SSD controller hardware, which means it is likely a bug in the firmware, or a bad interaction between the firmware and the FreeBSD hardware drivers.
