Hello and thanks for reading this.
I have a TrueNAS-12.0-U6 that was upgraded from FreeNAS-11.3-U5. It has one jail running URBackup everything works great apart from the jail will not start automatically. The auto-start is ticked I have even tried unticking saving settings and re-ticking it to see if it was just not saving the setting correctly. If I manually start the jail it works great and runs until the unit is restarted but then I have to manually restart the jail. I can not find any errors in the logs it is as if it just does not try to start the jail.
Thanks again for reading this any help will be most apricated. It is not a major problem but really annoying have to check every day to make sure it is working.
