Hey there,
I have a separate jail to read the values of my solar inverters. It runs a python script originally written for raspberry, but it works well in a jail. I can start that python script in daemon mode and it will send the values to my mqtt. Now I wanted to improve, as the daemon does not autostart at reboot. So I have written a script in /usr/local/etc/rc.d/ that works when called with onestart.
I did put smaemd_enable="YES" in /etc/rc.conf, but upon
Here my /etc/rc.conf
Has anyone an idea where to look for a solution? Of course I could just login after a reboot and manually start the daemon, but that's not very handy...
Thanks in advance for your help,
Anduril
#!/bin/sh . /etc/rc.subr name=smaemd rcvar=smaemd_enable start_cmd="${name}_start" stop_cmd="${name}_stop" #load_rc_Config $name smaemd_start() { /root/smaemd/sma-daemon.py start } smaemd_stop() { /root/smaemd/sma-daemon.py stop } run_rc_command "$1"
service smaemd start
it asked to enable in rc.conf. I even tried to add with sysrc, checked and tried again, without luck...Code:
root@SMA-EM:~ # sysrc smaemd_enable="YES" smaemd_enable: YES -> YES root@SMA-EM:~ # sysrc smaemd_enable smaemd_enable: YES root@SMA-EM:~ # service smaemd start /usr/local/etc/rc.d/smaemd: WARNING: $smaemd_enable is not set properly - see rc.conf(5). Cannot 'start' smaemd. Set smaemd_enable to YES in /etc/rc.conf or use 'onestart' instead of 'start'.
GNU nano 5.5 /etc/rc.conf cron_flags="$cron_flags -J 15" # Disable Sendmail by default sendmail_enable="NO" sendmail_submit_enable="NO" sendmail_outbound_enable="NO" sendmail_msp_queue_enable="NO" # Run secure syslog syslogd_flags="-c -ss" # Enable IPv6 ipv6_activate_all_interfaces="YES" smaemd_enable="YES"
Anduril
