I have FreeNAS 9.1.1 (x64) up and running with:
HP N36L with 8 Gb (to be replaced with N54L & 16 Gb by end of year)
6x 2 Tb disks in raidz1 ( to be replaced with 6x 3Tb this week) zfs, nfs shared
1 USB attached 2,5 inch WDC 320Gb with a ~120 Gb UFS mount and a ~120 Gb zfs mount (Jail)
2 NICs, the default bge0 and an additional pcie x1 as vge0.
I have an ADSL connection with a simple router (from the provider) which is connected to bge0.
On top of the simple router I have also an D-LINK DHP-1565 which provides the Wifi and Wifi-guest networks and some wired connections to a xbmc box, an additional Wifi AP and to the FreeNAS box, through vge0.
This is the output of netstat -rn from FreeNAS:
I have been experiencing a lot with possible network options for my Jails, but can't get it to work to ping, pkg install, pkg_add -r or any other network command from a Plugin or Jail. This is a requisite however for SABnzbd/Couchpotato etc.
I can ping both gateways from FreeNAS, the internet, as well as the IP's of the Jails in zfs (jail).
I managed to get Jboss server running some handmade Scores through modyfing the default nginx configuration (adding my own config through an include statement in the nginx.conf and the /etc/rc.d/ix-nginx). This is available from the Internet through the reverse proxy.
From inside that Jboss Jail (and the other jails) I can't however make a connection outside the FreeNAS server. I can ping the IP's of the two interfaces as well as the other jails, but can't ping anything outside of FreeNAS, e.g. the gateway 192.168.1.1 or 192.168.2.1, do a pkg install, pkg_add -r or any other network command.
I have tried different options for a Jail by setting:
* a default IPv4 gateway
* enabling VIMAGE
* enabling NAT
But that doens't help at all.
I'm not a newbie at networking nor Linux/*BSD, but can't figure out how to properly configure my jails. The included plugins from appcafe for SAB, Couch etc, don't provide enough flexibility and control.
Destination Gateway Flags Refs Use Netif Expire default 192.168.1.1 UGS 0 43878 bge0 10.0.0.0/24 link#2 U 0 185 bge0 10.0.0.1 link#2 UHS 0 463 lo0 10.0.0.2 link#2 UHS 0 1151 lo0 10.0.0.3 link#2 UHS 0 13 lo0 127.0.0.1 link#11 UH 0 91489 lo0 192.168.1.0/24 link#2 U 0 157 bge0 192.168.1.11 link#2 UHS 0 447 lo0 192.168.2.0/24 link#1 U 0 165 vge0 192.168.2.30 link#1 UHS 0 450 lo0
* enabling VIMAGE
* enabling NAT
