Jailed Sickbeard TPB not starting
unca_NAS
Hello all
Installed the "torrent-friendly version" of Sickbeard
When calling it inside the jail with
python /.sickbeard/SickBeard.py -q
it starts normally.
Tried to autostart it by following file-modifications..
sickbeard_enable="YES"
python_enable="YES"
After restarting the jail the SB won't autostart. However it can be started manually.
What I'm missing here?
Thanks and have a good one :)
Joshua Parker Ruehlig
There is already a sickbeard plugin, so you should utilize it as much as you can. Here's what I recommend you do, assuming by TPB branch you mean SickRage.
  1. Install the sickbeard plugin
  2. Run the following in your sickbeard plugin jail
pkg install git
service sickbeard stop
rm -r /usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard /usr/pbi/sickbeard-amd64/etc/sickbeard/* && git clone git://github.com/echel0n/SickRage.git /usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard
chown -R media:media /usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard
service sickbeard start
This will replace your SickBeard source files with SickRage ones. You can start/stop/access the plugin from the FreeNAS menu just like it was the official plugin.
unca_NAS
Thank you kind Sir, will give this a try
Umm. Tried the long rm -r... command copypasting and typing it from start to end >> "rm: no match".
As if there were a typo somewhere? Or was the asterisk?
EDIT: the service was to be started from GUI prior editing jail. With the immortal words of one Homer J. Simpson... "DUH!"
